Date/Time: Mon, 21 Apr 2025 17:43:42 +0000
Support Reversals and Allow Multiple Entries In Same Direction not work on version1834
View Count: 1553
[2018-11-03 19:32:38]
User29582 - Posts: 33
Hi Support Team,
Long time Sierrachart user for 10 years.
Recent I tested "Support Reversals and Allow Multiple Entries In Same Direction" for Trading System Based on Alert Condition.
setup:
Maximum Position Allowed 5
Order Quantity 1
First buy on first bar close is working: buy 1
Second buy on second bar close is not working, didn't add second buy 1.
and Reversal is not happening: if I have 1 buy order and next 1 sell order cannot flat buy order and add 1 sell order.
Please validate ASAP and advise.
Peter
[2018-11-03 20:29:38]
We did test Allow Multiple Entries In Same Direction and see why there is a problem. This will be solved in the next release. We also implement to the same solution for Support Reversals.
Support Reversals and Allow Multiple Entries In Same Direction were added on user request and they were not tested. They just simply set the underlying automated trading variables which do work properly. The reason for the issue has to do with other safety checks that the Trading System Based on Alert Condition performs which prevented these Settings from having any effect. And the reason is clearly given when you enable debugging output.
Date Time Of Last Edit: 2018-11-03 20:30:30
[2018-11-03 23:14:32]
Thank you. waiting for the next Release.
This is key function for auto trade to work.
Thanks Again
Peter
[2022-11-17 12:06:00]
Tahir - Posts: 35
Hi, I am running v2417 and this issue still seams to be there. Is this still not updated or am I doing something wrong?
[2022-11-17 12:08:50]
Sierra_Chart Engineering - Posts: 19289
This is a very old thread. You should not have any issues. However, update to the current version of Sierra Chart:
[2023-02-12 20:56:29]
John M - Posts: 171
I am having the same issue with no reversals happening.
Reversal is not happening: if I have 1 sell order position filled and the next 1 buy order cannot flatten the existing position and issue new buy order .
This is in SC version 2466.
Support Reversals is ticked in the preferences. Cancel all Orders on Reversals is ticked in the preferences.
