Date/Time: Thu, 23 Jan 2025 02:46:25 +0000
Is SPX500 data reliable?
View Count: 1447
[2018-11-03 13:05:09] |
User563984 - Posts: 17 |
Hello, yesterday, friday 2018/11/02 on SPX500 the low was made at 2700.25 while on the E-mini the low was 2699.50. Shouldn't the SPX500 replicate the futures data? This is just one example, it's not the first time that I see small discrepancies between the two. I know it's only 3 ticks, but three ticks can make a hell of a difference if you consider context. thanks for your time! your software is great!! Regards, Matteo |
[2018-11-03 19:24:49] |
You cannot compare a CFD to a futures contract. They are definitely different. They will not match exactly.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-03 19:24:55
[2018-11-04 11:25:26] |
Ok. I get it. Just checking 'cause the broker with which I trade (PLUS500) uses CFD data from Investing.com and it matches the E-mini much more accurately than FXCM. But unfortunately I can't use it for Market Profile which is my main source of market generated information that I use to trade. Thank you for the reply. |
[2018-11-04 21:56:06] |
You could just use the ESZ18 Futures symbol instead.
[2018-11-05 09:15:42] |
Yes, I know, but I didn't want to pay the 35$ for SC Data feed + the ES exchange fees (I don't have a broker) that should be 42$ if I understood well enough?
[2018-11-05 09:30:25] |
Yes this is the cost if you do require real-time data. But the real-time data connection will be just 25USD for 20 symbols.
[2018-11-05 09:30:27] |
[2018-11-05 11:28:45] |
Sorry to bother you further but I am now a bit confused. In the 20 symbols that you are talking about is ES included? Does it mean that I only have to pay 25$ or that it is 25$ + CME exchange fees that adds up to 67$ total? Thanks for the patience. Regards |
[2018-11-05 17:44:01] |
In the 20 symbols that you are talking about is ES included? No. You will of course have to pay the exchange fee.
