Date/Time: Thu, 23 Jan 2025 02:40:48 +0000
s_UseTool::MarkerSize definitions
View Count: 650
[2018-11-03 11:35:43] |
binaryduke - Posts: 376 |
Hi SC Please could you provide some explanation of how the marker size relates to either pixels or the y-axis price scale. The objective is to specify a marker size that correlates to a known price range. Thanks BD. |
[2018-11-05 07:27:07] |
Tell us one of the markers you have a question about. Or two. But preferably not more right now.
[2018-11-05 07:42:25] |
MARKER_POINT
[2018-11-08 20:38:33] |
We are looking this over now.
[2018-11-08 21:08:41] |
The following has been added to the documentation: In the case of a Point marker drawing, the Size setting in the Drawing tool configuration specifies the half-size of the ellipse. So the diameter will be twice the size. When Size Based on Bar Spacing is enabled, then the size will be based on the chart bar spacing.
