Date/Time: Wed, 22 Jan 2025 23:14:08 +0000
Has trade occured using Bar Index
View Count: 626
[2018-11-02 17:10:20]
User316362 - Posts: 210
Is there a simple ACSIL function to check if a trade has occurred at a particular Bar Index? Might be better than using order entries and checking results (using allow 1 trade per bar).
Why not ovoid another order entry if a simple check can be made. (e.g. sc.NumberOfOrdersbyIndex or something like it)?
I guess I could persist the knowledge of a trade and check and clear that upon a new index.
Date Time Of Last Edit: 2018-11-02 17:35:20
[2018-11-02 17:41:41]
You can get the order fills:
Automated Trading From an Advanced Custom Study: sc.GetOrderFillEntry()
You can then access the FillDateTime of each fill.
[2018-11-02 17:51:40]
thanks, I'll implement this
