Date/Time: Thu, 23 Jan 2025 02:39:14 +0000
When Using CTS - Chart Trading Entry/Exit Connecting Lines are Vertical.
View Count: 804
[2018-11-02 15:16:27]
TapeReader - Posts: 89
I am using a test CTS account.
Previous to connecting to this CTS test account the Chart Trading Entry/Exit Connecting Lines spanned from trade entry to trade exit.
However, now that I am connected to the CTS connection, the connecting lines are vertical (see attached graphic).
Any insights into why this drawing behavior changed when connecting to CTS?
Is there a way to get the lines to revert to spanning from entry to exit with CTS?
imageCTS - Chart Trading - Entry Exit Connecting Lines.jpg / V - Attached On 2018-11-02 15:15:40 UTC - Size: 83.74 KB - 385 views
[2018-11-02 17:11:44]
Update to the current version following the instructions here:
[2018-11-04 14:15:02]
I updated to build 1835.
However, when I load our custom studies, I receive a "Windows error code 193:%1 is not a valid Win32 application" error. - see attached pic.
I have rolled Sierra Chart back to 1815 and this error no longer surfaces.
I will do some digging on our side of the fence.
Any insights from Sierra Chart engineering why this may have occurred?
imageBuild 1835 Windows Error Code 193.jpg / V - Attached On 2018-11-04 14:14:33 UTC - Size: 60.1 KB - 320 views
[2018-11-05 08:02:59]
This has been fixed in 1836 now.
[2018-11-06 14:17:35]
1836 remediated both the vertical connection line issue and the Windows error code 193 issue.
Thanks...
