Date/Time: Tue, 22 Apr 2025 18:16:46 +0000
DOM data - Download as CSV
View Count: 951
[2018-11-02 15:10:35] |
User726297 - Posts: 13 |
Hello, I know how to download tick data from SC, but I was wondering if I can download historical market depth data as a CSV, or if I can manage to store it and then to download it? Regards, |
[2018-11-02 17:43:12] |
No this is not supported.
[2025-01-01 23:05:45] |
jsandlan - Posts: 57 |
Is this still not supported?
[2025-01-02 00:51:48] |
Sierra_Chart Engineering - Posts: 19305 |
The most we can offer regarding this, is the Market Depth data file documentation: Market Depth Data File Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
