Date/Time: Wed, 22 Jan 2025 23:20:02 +0000
PC budgeting: Increase RAM from 16 to 32, OR get a 2nd NVME exclusively for Sierra?
View Count: 1137
[2018-11-02 14:57:06] |
RonW - Posts: 105 |
Replacing my 6 year old computer. I have read a bunch of threads on the Support Board about configurations. I will get a fast CPU with a bunch of cores, and at least 16GB of RAM and a NVME drive. If I have a little more room in the budget, should I spend it on doubling the RAM, or getting a 2nd NVME drive exclusively for Sierra? If you recommend the drive option, is 250GB enough or should I go for the 500GB? 2nd question... I am assuming a graphics card with 2-4 GB of memory is plenty, correct? |
[2018-11-02 17:44:27] |
or getting a 2nd NVME drive exclusively for Sierra? Yes. This is a good idea.Being the data is compressed, 250 GB should be fine. The graphics card sounds fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-02 17:44:38
