Date/Time: Wed, 22 Jan 2025 23:14:21 +0000
Using Sierra charts Update 1834 NO left click to change time
View Count: 1044
[2018-11-02 02:15:57]
User480071 - Posts: 2
Using Sierra charts Update 1834 NO left click to change time, and charts seconds do not update only show in minute barsno second bars updating using Rithmic data feed , can you please check on your version to make left click change times on chart easy thanks.
[2018-11-02 04:23:34]
We are not sure what you are referring to here. Can you explain this more?
1. Follow the instructions here to update the Symbol Settings:
2. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
