Date/Time: Wed, 22 Jan 2025 23:26:54 +0000
Calling sc.CloseFile() causes CPU exception
View Count: 603
[2018-11-01 23:45:52] |
User41727 - Posts: 124 |
Opening works fine, writing works fine, attempting to close the file causes a CPU exception, regardless of whether or not anything was written to it. Is this the expected behaviour? Also, the four modes for sc.OpenFile() cannot be found in any of the header files, nor is their behaviour properly documented. Date Time Of Last Edit: 2018-11-01 23:46:13
[2018-11-02 00:29:22] |
No definitely that is not the expected behavior at all. This will be corrected in the next release. These functions have not yet been documented. In the next release, the modes for the OpenFile function will be in the SCConstants.h file Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
