Date/Time: Wed, 22 Jan 2025 23:02:39 +0000
Text Display For Study
View Count: 938
[2018-11-01 22:35:39]
User21113 - Posts: 62
On a chart with 'Text Display For Study'.
As the numbers increase, 1/10/100/1000, the numbers are displayed as left justified.
Is it possible for the numbers be displayed as right justify?
[2018-11-02 14:12:11]
John - SC Support - Posts: 37418
No, this is not supported. The placement of the drawing is from the upper left hand corner, therefore the numbers are going to extend to the right as the number of digits increases.
[2018-11-02 17:33:05]
You can change this by modifying the source code:
How to Build an Advanced Custom Study from Source Code
