Date/Time: Thu, 23 Jan 2025 05:08:38 +0000
sc.PersistVars ERROR
View Count: 1380
[2018-11-01 16:57:17] |
User114959 - Posts: 10 |
Attempting to Rebuild custom function with no coding changes and receive the error: In Function 'void scsf_DPMR(SCStudyInterfaceRef)': DPMRNQ.cpp:85:25: error: 'struct s_sc' has no member named 'PersistVars' double& avgRange = sc.PersistVars->Doubles[0]; Receive this error for each line using PersistVar. This only starting occurring since the download of the most recent release update. Please advise Thank you |
[2018-11-01 18:04:35] |
You need to use the newer persistent variable functions instead: sc.GetPersistentInt() Example: double& avgRange = sc.GetPersistentDouble(1);
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-01 18:07:13
[2018-11-01 18:07:19] |
The prior post has been updated with an example.
[2018-11-01 19:07:41] |
Thank you for the quick response! That did the trick!
[2018-11-19 08:52:33] |
User88 - Posts: 40 |
The example below still uses the old method. ACSIL Programming Concepts: One Time Processing per Bar in the Chart Doc needs updating. |
[2018-11-19 10:13:15] |
We will do this now.
