Date/Time: Thu, 23 Jan 2025 02:25:17 +0000
[Programming Help] - Distance from a line
View Count: 873
[2018-11-01 14:55:45] |
User798620 - Posts: 29 |
i have a trade i love to take, but i only take it if price is within a certain amount of pips from my indicator. i have already created my alert. but i cant figure out how to add this rule. (pip distance from my indicator...) this seems like a pretty straightforward thing to need. is it possible to add this to my alert, if so what would the formula look like? also on a side note, is there a way to get alerted when price comes within a certain number of pips from my indicator/line as well? Date Time Of Last Edit: 2018-11-01 15:06:23
[2018-11-01 19:32:41] |
Refer to: http://www.sierrachart.com/index.php?page=doc/ArithmeticStudies.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-09 16:10:59] |
i dont seem to understand this after a week of re reading, do you have a video that might help with this?
