Date/Time: Thu, 23 Jan 2025 00:00:58 +0000
VpB Visible Bars
View Count: 800
[2018-11-01 14:35:10] |
BLAKE R - Posts: 23 |
Good Day, I am using VpB as an alert for both sell and buy entries. The plotted line ID".SG4 is working as entered. However, ID".SG3 is not. I would like to take long trades only when C>ID".SG3. Although SG4 works fine, SG3 does not. I have reworked the syntax many different ways and get the same result. Any suggestions? Thanks, Blake |
[2018-11-01 19:30:53] |
Follow the instructions here to see that Subgraph: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines Make sure it is actually visible and contains the value that you expect at the last chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-01 19:31:01
