Date/Time: Thu, 23 Jan 2025 00:09:59 +0000
chart padding not enough to keep candles on screen when price gets to the bottom or top
View Count: 633
[2018-11-01 13:29:02] |
canyiah - Posts: 48 |
When price rallys up to the current max price on the y axis the price is not visible without manually re-aligning the chart. Current i have it on keep in view within 10 price levels. http://www.sierrachart.com/image.php?Image=1541078893514.png |
[2018-11-01 17:48:43] |
Refer to the instructions here: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
