Date/Time: Sun, 24 Nov 2024 12:14:24 +0000
ATR location Anyway to have just the ATR value show , say in the upper left hand corner of the m
View Count: 1216
[2013-10-31 20:34:28] |
steve i depner - Posts: 14 |
Anyway to have just the ATR value show , say in the upper left hand corner of the main graph? I just want the value, nothing else.
[2013-10-31 20:38:31] |
ganz - Posts: 1048 |
steve i depner http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s295 |
[2013-11-03 20:15:22] |
Use Text Display for Study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s295 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
