Date/Time: Thu, 23 Jan 2025 00:00:03 +0000
Excluding Rectangle Tool to be copied to other charts
View Count: 578
[2018-11-01 10:18:22] |
ILIM KIRGIZ - Posts: 187 |
I use SC's copy chart drawings from chart #'s function. I need to exclude single drawing from being copied which is the Rectangle tool. Is that possible to achieve this? Thanks. |
[2018-11-01 19:20:56] |
No, this is not supported.
