Date/Time: Wed, 22 Jan 2025 23:57:34 +0000
DOwnload Issues and need to change to 32bit version
View Count: 771
[2018-10-31 22:43:01] |
User96868 - Posts: 3 |
HAving lots of trouble with the download. I had to install parralels desktop and it's been a pain on my mac. Also, i never got asked if i wanted 32 bit or not. I need help. Pls let me know when you can help.
[2018-11-01 00:16:22] |
Each installation of Sierra Chart has both a 64-bit and 32-bit Version. Refer to: Software Download: Difference Between 32 and 64-bit Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-01 00:25:15] |
Is there any way to speak with someone? I run MAC OS and had to install windows so CS can run, and I cannot access the C:/sierrachart folder
[2018-11-01 00:39:09] |
This is not something we think we can help you with. We are not ourselves familiar with the Mac operating system. Refer to this documentation here about this: https://download.parallels.com/desktop/v12/docs/en_US/Getting%20Started%20With%20Parallels%20Desktop.pdf Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
