Date/Time: Thu, 23 Jan 2025 00:11:45 +0000
Can i make all symbols in a chartbook appear in the chartbooks miditab?
View Count: 738
[2018-10-31 16:56:05] |
User138602 - Posts: 169 |
Hello, i think i did read something about the possibility to show timeframes in the miditabs. I REALLY would love to have this feature for the symbols. I use already 5 monitors and more are to come. But i use 1 monitore alone for 5 and more chartbooks to see all relevant timeframes for 2 symbols in each one. I change the symbols VERY regularly according to what positions i have and what symbols i want to watch closely. The problem is to remember where each symbol is. I could save the chartbook each time i change a symbol and give it the according name. But i would end up with ALOT of chartbook save files. So could i get an option to achieve what i want? Just a checkbox in the chartsettings, like: "Show this charts symbol in the Chartbook Miditab". Best Regards |
[2018-10-31 19:53:30] |
This is not making sense to us because the MDI tabs do show the symbol and the chart bar timeframe.
[2018-10-31 20:25:15] |
I most certainly did confuse things. When i open a new chartbook, the chartbook tab is named "Chartbook4" by default, in the case 3 other chartbooks are already open. I would like to get this labeled as described above. Labeled by the symbols of the different charts i select...on the fly....each time i change a symbol. |
[2018-10-31 21:46:06] |
The name of on a Chartbook tab itself is going to be the name of the Chartbook. So you just have to rename the Chartbooks. There is no other way to change those tab names. But you can also add tabs for the individual charts themselves. There is nothing further we can do to help with this.
