Date/Time: Wed, 22 Jan 2025 23:08:59 +0000
MA Convert to Horizontal Line
View Count: 627
[2018-10-31 16:34:15]
User371906 - Posts: 141
I want to know if it is possible to convert a moving average that I have overlaid from another chart to a horizontal line or dots in the middle of the screen?
http://www.sierrachart.com/image.php?Image=1541003327473.png
Thank You
Regards
g
[2018-10-31 19:51:39]
First, you have options to change how the line is displayed (solid, dot, dash, etc.). Refer to the following for this: Chart Studies: Subgraphs Tab >> Line Style
Additionally, you can change the Draw Style to something other than Line that may be more what you are looking for. Refer to the following for this: Chart Studies: Subgraphs Tab >> Draw Style
The one thing to keep in mind is that if you mentioned using an Overlay, therefore, you may have to change the Subgraph settings in the original chart, depending on how you have the Overlay study configured. Refer to the following: Study/Price Overlay Study: Use Styles and Widths from Source Study
