Date/Time: Wed, 22 Jan 2025 23:59:09 +0000
Disconnecting 3 to 4 times a day ever since yr double digits
View Count: 666
[2018-10-31 15:17:02]
User450179 - Posts: 105
Hi
I am not sure what has happened to my Sierra chart but it tends to drop off/disconnect 2 to 4 times everyday for a second or 2. it does seem to
happen during a lot of mkt messaging but not sure if that is the problem. I did not notice this before the years changed to from 8 to 18 or single digit to double digit for futures. I am including my log file for the day which shows a microsoft error of 10053 but even after investigating that i am not sure what is going on.. thank you
JAY
p.s. while you are looking at my data service and trade service i was wondering if you would make sure I am using barchart for data andnot oec trader/GAIN whihc I am using for trading. in the log it says data/trade service gain.
My second instance of sierra chart is not using bar chart since I do not see a bracketed M.
thank you
JAY
Reading Internal Order ID file. | 2018-10-30 07:33:24
Reading Trade Orders file. | 2018-10-30 07:33:24
Reading Trade Positions file. | 2018-10-30 07:33:24
Account Balance file. | 2018-10-30 07:33:24
Listening on UDP port 22904. | 2018-10-30 07:33:24
Software version: 1827 64-bit | 2018-10-30 07:33:24
Usage end date: 2019-01-09 | 2018-10-30 07:33:24
Enabled for: Advanced Features. | 2018-10-30 07:33:24
Enabled for: Sierra Chart Historical Data Service. | 2018-10-30 07:33:24
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-10-30 07:33:24
Enabled for: INDEXES_DATA_BARCHART | 2018-10-30 07:33:24
Enabled for: CME with Market Depth for nonprofessional Trading accounts | 2018-10-30 07:33:24
Enabled for: CBOT (Trading Account Required) | 2018-10-30 07:33:24
Enabled for: COMEX (Trading Account Required) | 2018-10-30 07:33:24
Enabled for: NYMEX (Trading Account Required) | 2018-10-30 07:33:24
Enabled for: U.S. Equities (NYSE, NASDAQ, AMEX, BATS) | 2018-10-30 07:33:24
Enabled for: BATS (NYSE, NASDAQ) | 2018-10-30 07:33:24
Enabled for: Hong Kong Futures Exchange | 2018-10-30 07:33:24
Received 1 data feed usernames. | 2018-10-30 07:33:24
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-10-30 07:33:24
Current selected Data/Trading service: GAIN Capital/OEC | 2018-10-30 07:33:24
Chart Update Interval: 75 | 2018-10-30 07:33:24
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-10-30 07:33:24
2018-10-30 07:33:23 Local computer time | 2018-10-30 07:33:24
2018-10-30 11:33:23 Local computer time in UTC | 2018-10-30 07:33:24
2018-10-30 07:33:23 Local computer time in SC Time Zone | 2018-10-30 07:33:24
2018-10-30 11:33:22 Server time in UTC | 2018-10-30 07:33:24
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-10-30 07:33:24
Program path: C:\SierraChart\ | 2018-10-30 07:33:24
Data Files path: C:\SierraChart\Data\ | 2018-10-30 07:33:24
OS Version Number: 10.0 | 2018-10-30 07:33:24
Locale Setting: C | 2018-10-30 07:33:24
Created the DTC Protocol server. | 2018-10-30 07:33:24
DTC Protocol Server listening on port 11099. | 2018-10-30 07:33:24
Created the DTC Protocol historical data server. | 2018-10-30 07:33:24
HD Server Manager | Listening on port 11098 | 2018-10-30 07:33:24
Checking for new symbol settings for service code oec | 2018-10-30 07:33:24
HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-10-30 07:33:24
HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-10-30 07:33:24
Symbol settings are up-to-date for oec | 2018-10-30 07:33:24
Received 5 login tokens. | 2018-10-30 07:33:24
HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-10-30 07:33:26
HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-10-30 07:33:26
HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-10-30 07:33:28
HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-10-30 07:33:28
HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-10-30 07:33:28
HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:33:28
HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-10-30 07:33:28
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-10-30 07:33:29
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2018-10-30 07:33:29
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:33:29
HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-10-30 07:33:29
GAIN Capital FIX Trading: Sending the Logon message. | 2018-10-30 07:33:30
GAIN Capital FIX Trading | Connected to trading server. | 2018-10-30 07:33:30
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-10-30 07:33:30
GAIN Capital FAST Data socket (2) | Creating socket. | 2018-10-30 07:33:30
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2018-10-30 07:33:30
GAIN Capital FAST Data: Sent the Hello message. | 2018-10-30 07:33:30
GAIN Capital FAST Data: Sent the Logon message. | 2018-10-30 07:33:30
GAIN Capital/OEC | Connected to data and trading server. | 2018-10-30 07:33:30
HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-10-30 07:33:31
HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-10-30 07:33:31
Created process C:\SierraChart\SierraChartInstance_2\SierraChart_64.exe. Parameters: /enc:I-eH749SGNCiL-9SL4i-hti5h+GHL4CPTxQoLchS7Kdq~gGHLKCELNfi73Z1KS6lLxz$Gt6BlxQi7nGHg6OpKKCELNCEg49SGNCiL6lHhtOq~3ex$3qc~zi7gzk1KKCELNCE9-9EL@Z8~3G.$+GHK86wKSplgt9Eg6OpK4CPrxQoLchS7KdpGcfwGtOq7Nh+LKdc~9PpQx6ih4CSLSQ-GxdqTNh.L-m-7cCE$Ydc~9Pp9choL4HHhNOq7t95hNQuGNCob@fU. Current folder: C:\SierraChart\SierraChartInstance_2 | 2018-10-30 07:33:35
HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-10-30 07:33:35
HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:33:35
HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-10-30 07:33:35
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 07:33:35
DTC Protocol server | Incoming connection from 127.0.0.1. | 2018-10-30 07:33:45
DTCServer (3) | Creating socket. | 2018-10-30 07:33:45
DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2018-10-30 07:33:45
DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2018-10-30 07:33:45
DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2018-10-30 07:33:45
DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: jaytrader75. Result text: Connected to SC DTC Protocol server. Service=oec|SymbolSettings=oec | 2018-10-30 07:33:45
NQz18 3 Min #1 | Reloading chart. | 2018-10-30 07:34:26
YMZ18 5 Sec #3 | Reloading chart. | 2018-10-30 07:34:27
YMZ18 3 Min #4 | Reloading chart. | 2018-10-30 07:34:27
YMz18 5 Trades #6 | Reloading chart. | 2018-10-30 07:34:27
YMZ18 1 Sec #11 | Reloading chart. | 2018-10-30 07:34:27
NQZ18 0.25 Range #5 | Reloading chart. | 2018-10-30 07:34:27
RTYz18 3 Min #13 | Reloading chart. | 2018-10-30 07:34:27
YMz18 1 Range #15 | Reloading chart. | 2018-10-30 07:34:27
YMZ18 10 Min #16 | Reloading chart. | 2018-10-30 07:34:27
NQz18 3 Min #1 | Reloading chart. | 2018-10-30 07:34:27
ESz18 20 Sec #3 | Reloading chart. | 2018-10-30 07:34:27
ESZ18 2 Min #4 | Reloading chart. | 2018-10-30 07:34:27
ESz18 10 Trades #6 | Reloading chart. | 2018-10-30 07:34:27
ESZ18 1 Sec #11 | Reloading chart. | 2018-10-30 07:34:27
ESz18 0.25 Range #5 | Reloading chart. | 2018-10-30 07:34:27
ESZ18 2 Min #13 | Reloading chart. | 2018-10-30 07:34:27
ESz18 30 Sec #15 | Reloading chart. | 2018-10-30 07:34:27
ESZ18 [C] 5 Min #16 | Reloading chart. | 2018-10-30 07:34:27
NQZ18 10 Min #1 | Reloading chart. | 2018-10-30 07:34:28
NQZ18 2 Sec #3 | Reloading chart. | 2018-10-30 07:34:28
NQz18 3 Min #4 | Reloading chart. | 2018-10-30 07:34:28
NQz18 30 Sec #6 | Reloading chart. | 2018-10-30 07:34:28
NQz18 2 Min #5 | Reloading chart. | 2018-10-30 07:34:28
ESZ18 2 Min #13 | Reloading chart. | 2018-10-30 07:34:28
NQz18 60 Min #9 | Reloading chart. | 2018-10-30 07:34:28
NQZ18 6 Trades #16 | Reloading chart. | 2018-10-30 07:34:28
NQz18 [CV] Daily #2 | Reloading chart. | 2018-10-30 07:34:29
NQz18 [CV] 30 Min #7 | Reloading chart. | 2018-10-30 07:34:29
ESz18 3 Min #1 | Reloading chart. | 2018-10-30 07:34:29
RTYz18 30 Sec #3 | Reloading chart. | 2018-10-30 07:34:29
RTYz18 3 Min #4 | Reloading chart. | 2018-10-30 07:34:30
RTYz18 1 Min #6 | Reloading chart. | 2018-10-30 07:34:30
RTYz18 10 Sec #11 | Reloading chart. | 2018-10-30 07:34:30
NQz18 3 Min #13 | Reloading chart. | 2018-10-30 07:34:30
RTYz18 5 Trades #15 | Reloading chart. | 2018-10-30 07:34:30
RTYZ18 10 Min #16 | Reloading chart. | 2018-10-30 07:34:30
Chart #11 has tagged chart #3 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 07:34:30
Chart #11 has tagged chart #4 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 07:34:30
Chart #11 has tagged chart #3 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:32
Chart #11 has tagged chart #4 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:32
Chart #11 has tagged chart #3 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 07:34:32
Chart #11 has tagged chart #4 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 07:34:32
Mapping NQz18 to NQZ18. Service code: cme | 2018-10-30 07:34:32
SC Data - All Services | Starting real-time market data updates for: NQZ18. ID: 1 | 2018-10-30 07:34:32
SC Data - All Services | Using username 0 | 2018-10-30 07:34:32
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-10-30 07:34:32
SC Data - All Services | Requesting security definition data for: NQZ18. ID: 1 | 2018-10-30 07:34:32
Intraday data recording state for symbol NQz18 is set to download 'Pending'. | 2018-10-30 07:34:32
Delaying start of download for NQz18 | 2018-10-30 07:34:32
Mapping YMZ18 to YMZ18. Service code: cbot | 2018-10-30 07:34:32
SC Data - All Services | Starting real-time market data updates for: YMZ18. ID: 2 | 2018-10-30 07:34:32
SC Data - All Services | Requesting security definition data for: YMZ18. ID: 2 | 2018-10-30 07:34:32
Intraday data recording state for symbol YMZ18 is set to download 'Pending'. | 2018-10-30 07:34:32
YMZ18 [M] 5 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 07:34:32
YMZ18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 07:34:32
Mapping RTYz18 to RTYZ18. Service code: cme | 2018-10-30 07:34:32
SC Data - All Services | Starting real-time market data updates for: RTYZ18. ID: 3 | 2018-10-30 07:34:32
SC Data - All Services | Requesting security definition data for: RTYZ18. ID: 3 | 2018-10-30 07:34:32
Intraday data recording state for symbol RTYz18 is set to download 'Pending'. | 2018-10-30 07:34:32
DTC Client socket (4) | Creating socket. | 2018-10-30 07:34:32
DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2018-10-30 07:34:32
Mapping ESz18 to ESZ18. Service code: cme | 2018-10-30 07:34:32
SC Data - All Services | Starting real-time market data updates for: ESZ18. ID: 4 | 2018-10-30 07:34:32
SC Data - All Services | Requesting security definition data for: ESZ18. ID: 4 | 2018-10-30 07:34:32
Intraday data recording state for symbol ESz18 is set to download 'Pending'. | 2018-10-30 07:34:32
ESz18 [M] 20 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:32
SC Data - All Services | Connected to server. | 2018-10-30 07:34:32
SC Data - All Services | Starting socket receive thread. | 2018-10-30 07:34:32
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-10-30 07:34:32
ESZ18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:32
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-10-30 07:34:33
SC Data - All Services | Sending logon request message. | 2018-10-30 07:34:33
HD Request # 2 | Downloading Historical Daily chart data for NQz18. Starting date: 2018-10-29. Service: oec | 2018-10-30 07:34:33
HD Request # 2 | Using user Barchart Historical data account. | 2018-10-30 07:34:33
HD Request # 2 | Requesting historical Daily data for NQz18 starting at 2018-10-28 | 2018-10-30 07:34:33
RTYz18 [M] 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 07:34:33
RTYz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 07:34:33
SC Data - All Services | Received logon response. | 2018-10-30 07:34:33
SC Data - All Services | Server Name: SC Realtime Server. | 2018-10-30 07:34:33
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-10-30 07:34:33
SC Data - All Services | Successfully connected. | 2018-10-30 07:34:33
SC Data - All Services | Trading is not supported. | 2018-10-30 07:34:33
SC Data - All Services | Restarting real-time data updates for symbol: ESz18 -> ESZ18 | 2018-10-30 07:34:33
SC Data - All Services | Restarting real-time data updates for symbol: NQz18 -> NQZ18 | 2018-10-30 07:34:33
SC Data - All Services | Restarting real-time data updates for symbol: RTYz18 -> RTYZ18 | 2018-10-30 07:34:33
SC Data - All Services | Restarting real-time data updates for symbol: YMZ18 -> YMZ18 | 2018-10-30 07:34:33
HTTPS historicaldata.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-10-30 07:34:33
HTTPS historicaldata.sierrachart.com:443 (5) | Connecting to IP: 88.99.0.216. | 2018-10-30 07:34:33
Requesting market depth updates for: ESz18 if supported. | 2018-10-30 07:34:33
Requesting market depth updates for: NQz18 if supported. | 2018-10-30 07:34:33
Requesting market depth updates for: YMZ18 if supported. | 2018-10-30 07:34:33
SC Data - All Services | Received security definition for symbol ESz18 | 2018-10-30 07:34:33
SC Data - All Services | Received security definition for symbol NQz18 | 2018-10-30 07:34:33
SC Data - All Services | Received security definition for symbol RTYz18 | 2018-10-30 07:34:33
SC Data - All Services | Received security definition for symbol YMZ18 | 2018-10-30 07:34:33
SC Data - All Services | Clearing market depth for ESz18. | 2018-10-30 07:34:33
SC Data - All Services | Clearing market depth for NQz18. | 2018-10-30 07:34:33
SC Data - All Services | Clearing market depth for YMZ18. | 2018-10-30 07:34:33
HD Request # 2 | Receiving historical Daily data for NQz18 starting at 2018-10-29 | 2018-10-30 07:34:34
HD Request # 2 | Writing historical Daily data to the file NQz18.dly | 2018-10-30 07:34:34
HD Request # 2 | Received 2 records from 2018-10-29 00:00:00 to 2018-10-30 00:00:00 (2.0 days) and wrote 2 records for NQz18 | 2018-10-30 07:34:34
HD Request # 2 | Completion time: 2s | 2018-10-30 07:34:34
HD Request # 2 | Daily data download complete for NQz18. Unique request ID: 5 | 2018-10-30 07:34:34
Removed historical data download ID 5 | 2018-10-30 07:34:34
NQz18 [CV] [M] Daily #2 | Reloading chart. | 2018-10-30 07:34:34
HD Request # 3 | Downloading Intraday chart data for NQz18 to the file NQz18.scid. Service: cme | 2018-10-30 07:34:38
HD Request # 3 | Download start date-time: 2018-10-29 23:51:40.000 | 2018-10-30 07:34:38
HD Request # 3 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 07:34:38
Socket (6) | Creating socket. | 2018-10-30 07:34:38
Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-30 07:34:38
HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-10-30 07:34:38
HD Request # 3 | Sending historical data logon request message. | 2018-10-30 07:34:38
HD Request # 3 | Requesting Intraday data. Start date-time: 2018-10-29 23:51:40. Record interval: 0. Symbol: NQZ18 | 2018-10-30 07:34:38
HD Request # 3 | Decompressing data. | 2018-10-30 07:34:38
HD Request # 3 | Receiving Intraday data for NQz18 starting at 2018-10-29 23:51:40 | 2018-10-30 07:34:38
HD Request # 3 | Timestamp of first Intraday data file record written: 2018-10-29 23:51:47 | 2018-10-30 07:34:38
Socket (6) | Signaling to core to close socket | 2018-10-30 07:34:38
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 07:34:38
Historical data download thread signaled to stop. | 2018-10-30 07:34:38
HD Request # 3 | Received 63151 records from 2018-10-29 23:51:40 to 2018-10-30 07:34:34 (7.7 hours) and wrote 63150 records for NQz18 | 2018-10-30 07:34:38
Added 17 Time and Sales records to Intraday data file for NQz18 after download. | 2018-10-30 07:34:38
HD Request # 3 | Completion time: 0s | 2018-10-30 07:34:38
HD Request # 3 | Intraday data download complete for NQz18. Unique request ID: 1 | 2018-10-30 07:34:38
Removed historical data download ID 1 | 2018-10-30 07:34:38
Real-time Intraday chart data file updates started for NQz18 | 2018-10-30 07:34:38
Intraday chart data file opened for NQz18 | 2018-10-30 07:34:38
HD Request # 4 | Downloading Intraday chart data for YMZ18 to the file YMZ18.scid. Service: cbot | 2018-10-30 07:34:38
HD Request # 4 | Download start date-time: 2018-10-29 23:51:35.000 | 2018-10-30 07:34:38
HD Request # 4 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 07:34:38
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 07:34:38
Socket (6) | Closed. | 2018-10-30 07:34:38
Chart #3 has tagged chart #4 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 07:34:38
Chart #3 has tagged chart #6 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 07:34:38
Chart #3 has tagged chart #7 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 07:34:38
Socket (7) | Creating socket. | 2018-10-30 07:34:38
Socket (7) | Connecting to IP: 8.18.161.135. | 2018-10-30 07:34:38
NQz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 07:34:38
HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-10-30 07:34:38
HD Request # 4 | Sending historical data logon request message. | 2018-10-30 07:34:38
NQz18 [M] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 07:34:38
HD Request # 4 | Requesting Intraday data. Start date-time: 2018-10-29 23:51:35. Record interval: 0. Symbol: YMZ18 | 2018-10-30 07:34:38
NQz18 [CV] [M] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 07:34:38
HD Request # 4 | Decompressing data. | 2018-10-30 07:34:38
HD Request # 4 | Receiving Intraday data for YMZ18 starting at 2018-10-29 23:51:35 | 2018-10-30 07:34:39
HD Request # 4 | Timestamp of first Intraday data file record written: 2018-10-29 23:51:47 | 2018-10-30 07:34:39
Socket (7) | Signaling to core to close socket | 2018-10-30 07:34:39
Socket (7) | Shutdown started. Waiting for graceful close. | 2018-10-30 07:34:39
Historical data download thread signaled to stop. | 2018-10-30 07:34:39
HD Request # 4 | Received 28986 records from 2018-10-29 23:51:35 to 2018-10-30 07:34:35 (7.7 hours) and wrote 28985 records for YMZ18 | 2018-10-30 07:34:39
Added 2 Time and Sales records to Intraday data file for YMZ18 after download. | 2018-10-30 07:34:39
HD Request # 4 | Completion time: 0s | 2018-10-30 07:34:39
HD Request # 4 | Intraday data download complete for YMZ18. Unique request ID: 2 | 2018-10-30 07:34:39
Removed historical data download ID 2 | 2018-10-30 07:34:39
Real-time Intraday chart data file updates started for YMZ18 | 2018-10-30 07:34:39
Intraday chart data file opened for YMZ18 | 2018-10-30 07:34:39
HD Request # 5 | Downloading Intraday chart data for RTYz18 to the file RTYz18.scid. Service: cme | 2018-10-30 07:34:39
HD Request # 5 | Download start date-time: 2018-10-29 23:51:36.000 | 2018-10-30 07:34:39
HD Request # 5 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 07:34:39
Socket (6) | Creating socket. | 2018-10-30 07:34:39
Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-30 07:34:39
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 07:34:39
Socket (7) | Closed. | 2018-10-30 07:34:39
Chart #11 has tagged chart #3 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 07:34:39
Chart #11 has tagged chart #4 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 07:34:39
Chart #11 has tagged chart #5 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 07:34:39
YMZ18 [M] 5 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 07:34:39
HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-10-30 07:34:39
HD Request # 5 | Sending historical data logon request message. | 2018-10-30 07:34:39
HD Request # 5 | Requesting Intraday data. Start date-time: 2018-10-29 23:51:36. Record interval: 0. Symbol: RTYZ18 | 2018-10-30 07:34:39
NQZ18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 07:34:39
HD Request # 5 | Decompressing data. | 2018-10-30 07:34:39
HD Request # 5 | Receiving Intraday data for RTYz18 starting at 2018-10-29 23:51:36 | 2018-10-30 07:34:39
HD Request # 5 | Timestamp of first Intraday data file record written: 2018-10-29 23:52:45 | 2018-10-30 07:34:39
Socket (6) | Signaling to core to close socket | 2018-10-30 07:34:39
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 07:34:39
HD Request # 5 | Received 8487 records from 2018-10-29 23:51:36 to 2018-10-30 07:34:34 (7.7 hours) and wrote 8486 records for RTYz18 | 2018-10-30 07:34:39
Added 2 Time and Sales records to Intraday data file for RTYz18 after download. | 2018-10-30 07:34:39
HD Request # 5 | Completion time: 0s | 2018-10-30 07:34:39
HD Request # 5 | Intraday data download complete for RTYz18. Unique request ID: 3 | 2018-10-30 07:34:39
Removed historical data download ID 3 | 2018-10-30 07:34:39
Real-time Intraday chart data file updates started for RTYz18 | 2018-10-30 07:34:39
Intraday chart data file opened for RTYz18 | 2018-10-30 07:34:39
HD Request # 6 | Downloading Intraday chart data for ESz18 to the file ESz18.scid. Service: cme | 2018-10-30 07:34:39
HD Request # 6 | Download start date-time: 2018-10-29 23:51:40.000 | 2018-10-30 07:34:39
HD Request # 6 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 07:34:39
Socket (7) | Creating socket. | 2018-10-30 07:34:39
Socket (7) | Connecting to IP: 8.18.161.135. | 2018-10-30 07:34:39
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 07:34:39
Socket (6) | Closed. | 2018-10-30 07:34:39
HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-10-30 07:34:39
HD Request # 6 | Sending historical data logon request message. | 2018-10-30 07:34:39
Chart #11 has tagged chart #3 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 07:34:39
Chart #11 has tagged chart #4 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 07:34:39
YMZ18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 07:34:39
Opened cached Intraday file: C:\SierraChart\Data\NQz18.scid | 2018-10-30 07:34:39
HD Request # 6 | Requesting Intraday data. Start date-time: 2018-10-29 23:51:40. Record interval: 0. Symbol: ESZ18 | 2018-10-30 07:34:39
Opened cached Intraday file: C:\SierraChart\Data\YMZ18.scid | 2018-10-30 07:34:39
RTYz18 [M] 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 07:34:39
RTYz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 07:34:39
HD Request # 6 | Decompressing data. | 2018-10-30 07:34:39
HD Request # 6 | Receiving Intraday data for ESz18 starting at 2018-10-29 23:51:40 | 2018-10-30 07:34:39
HD Request # 6 | Timestamp of first Intraday data file record written: 2018-10-29 23:51:56 | 2018-10-30 07:34:39
HD Request # 6 | Received 83819 records from 2018-10-29 23:51:40 to 2018-10-30 07:34:34 (7.7 hours) and wrote 83814 records for ESz18 | 2018-10-30 07:34:39
Added 29 Time and Sales records to Intraday data file for ESz18 after download. | 2018-10-30 07:34:39
HD Request # 6 | Completion time: 0s | 2018-10-30 07:34:39
HD Request # 6 | Intraday data download complete for ESz18. Unique request ID: 4 | 2018-10-30 07:34:39
Removed historical data download ID 4 | 2018-10-30 07:34:39
Real-time Intraday chart data file updates started for ESz18 | 2018-10-30 07:34:39
Intraday chart data file opened for ESz18 | 2018-10-30 07:34:39
Chart #11 has tagged chart #3 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:39
Chart #11 has tagged chart #4 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:39
Chart #11 has tagged chart #5 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:39
ESz18 [M] 20 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:40
ESZ18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:40
ESz18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 07:34:40
Opened cached Intraday file: C:\SierraChart\Data\RTYz18.scid | 2018-10-30 07:34:42
Opened cached Intraday file: C:\SierraChart\Data\ESz18.scid | 2018-10-30 07:34:42
GAIN Capital/OEC | Starting real-time market data updates for: VXX18. ID: 5 | 2018-10-30 07:35:46
GAIN Capital/OEC | Requesting security definition data for: VXX18. ID: 5 | 2018-10-30 07:35:46
Mapping HSx18 to HSX18. Service code: HongKongFutures.Exchange | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: HSX18. ID: 6 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: HSX18. ID: 6 | 2018-10-30 07:35:46
Mapping GCLZ18 to CLZ18. Service code: nymex | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: CLZ18. ID: 7 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: CLZ18. ID: 7 | 2018-10-30 07:35:46
Mapping GGCZ18 to GCZ18. Service code: comex | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: GCZ18. ID: 8 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: GCZ18. ID: 8 | 2018-10-30 07:35:46
Mapping GHGZ18 to HGZ18. Service code: comex | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: HGZ18. ID: 9 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: HGZ18. ID: 9 | 2018-10-30 07:35:46
GAIN Capital/OEC | Starting real-time market data updates for: XBTX18. ID: 10 | 2018-10-30 07:35:46
GAIN Capital/OEC | Requesting security definition data for: XBTX18. ID: 10 | 2018-10-30 07:35:46
Mapping 6EZ18 to 6EZ18. Service code: cme | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: 6EZ18. ID: 11 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: 6EZ18. ID: 11 | 2018-10-30 07:35:46
Mapping 6JZ18 to 6JZ18. Service code: cme | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: 6JZ18. ID: 12 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: 6JZ18. ID: 12 | 2018-10-30 07:35:46
Mapping 6SZ18 to 6SZ18. Service code: cme | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: 6SZ18. ID: 13 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: 6SZ18. ID: 13 | 2018-10-30 07:35:46
Mapping GEZ18 to GEZ18. Service code: cme | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: GEZ18. ID: 14 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: GEZ18. ID: 14 | 2018-10-30 07:35:46
Mapping ZTZ18 to ZTZ18. Service code: cbot | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: ZTZ18. ID: 15 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: ZTZ18. ID: 15 | 2018-10-30 07:35:46
Mapping ZNZ18 to ZNZ18. Service code: cbot | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: ZNZ18. ID: 16 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: ZNZ18. ID: 16 | 2018-10-30 07:35:46
GAIN Capital/OEC | Starting real-time market data updates for: $TNX. ID: 17 | 2018-10-30 07:35:46
GAIN Capital/OEC | Requesting security definition data for: $TNX. ID: 17 | 2018-10-30 07:35:46
Mapping LBSF19 to LBSF19. Service code: cme | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: LBSF19. ID: 18 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: LBSF19. ID: 18 | 2018-10-30 07:35:46
Mapping ZCZ18 to ZCZ18. Service code: cbot | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: ZCZ18. ID: 19 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: ZCZ18. ID: 19 | 2018-10-30 07:35:46
Mapping ZSF19 to ZSF19. Service code: cbot | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: ZSF19. ID: 20 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: ZSF19. ID: 20 | 2018-10-30 07:35:46
Mapping GLD to GLD. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: GLD. ID: 21 | 2018-10-30 07:35:46
SC Data - All Services | Using username 0 | 2018-10-30 07:35:46
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-10-30 07:35:46
DTC Client socket (6) | Creating socket. | 2018-10-30 07:35:46
DTC Client socket (6) | Connecting to IP: 8.18.161.135. | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: GLD. ID: 21 | 2018-10-30 07:35:46
Mapping SLV to SLV. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: SLV. ID: 22 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: SLV. ID: 22 | 2018-10-30 07:35:46
Mapping FB to FB. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: FB. ID: 23 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: FB. ID: 23 | 2018-10-30 07:35:46
Mapping AMZN to AMZN. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: AMZN. ID: 24 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: AMZN. ID: 24 | 2018-10-30 07:35:46
Mapping GOOG to GOOG. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: GOOG. ID: 25 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: GOOG. ID: 25 | 2018-10-30 07:35:46
Mapping AAPL to AAPL. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: AAPL. ID: 26 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: AAPL. ID: 26 | 2018-10-30 07:35:46
Mapping NFLX to NFLX. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: NFLX. ID: 27 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: NFLX. ID: 27 | 2018-10-30 07:35:46
Mapping TSLA to TSLA. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: TSLA. ID: 28 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: TSLA. ID: 28 | 2018-10-30 07:35:46
Mapping BABA to BABA. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: BABA. ID: 29 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: BABA. ID: 29 | 2018-10-30 07:35:46
Mapping GDX to GDX. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: GDX. ID: 30 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: GDX. ID: 30 | 2018-10-30 07:35:46
Mapping PUTW to PUTW. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: PUTW. ID: 31 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: PUTW. ID: 31 | 2018-10-30 07:35:46
Mapping NVDA to NVDA. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: NVDA. ID: 32 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: NVDA. ID: 32 | 2018-10-30 07:35:46
Mapping INTC to INTC. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: INTC. ID: 33 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: INTC. ID: 33 | 2018-10-30 07:35:46
Mapping AMD to AMD. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: AMD. ID: 34 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: AMD. ID: 34 | 2018-10-30 07:35:46
Mapping JT to JT. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: JT. ID: 35 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: JT. ID: 35 | 2018-10-30 07:35:46
Mapping SNAP to SNAP. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: SNAP. ID: 36 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: SNAP. ID: 36 | 2018-10-30 07:35:46
Mapping GE to GE. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: GE. ID: 37 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: GE. ID: 37 | 2018-10-30 07:35:46
Mapping CNET to CNET. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: CNET. ID: 38 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: CNET. ID: 38 | 2018-10-30 07:35:46
Mapping MSFT to MSFT. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: MSFT. ID: 39 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: MSFT. ID: 39 | 2018-10-30 07:35:46
Mapping ULTA to ULTA. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: ULTA. ID: 40 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: ULTA. ID: 40 | 2018-10-30 07:35:46
Mapping HD to HD. Service code: equities.us | 2018-10-30 07:35:46
SC Data - All Services | Starting real-time market data updates for: HD. ID: 41 | 2018-10-30 07:35:46
SC Data - All Services | Requesting security definition data for: HD. ID: 41 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol HSx18 | 2018-10-30 07:35:46
SC Data - All Services | Connected to server. | 2018-10-30 07:35:46
SC Data - All Services | Starting socket receive thread. | 2018-10-30 07:35:46
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol GCLZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol GGCZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol GHGZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol 6EZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol 6JZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol 6SZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol GEZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol ZTZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol ZNZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol LBSF19 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol ZCZ18 | 2018-10-30 07:35:46
SC Data - All Services | Received security definition for symbol ZSF19 | 2018-10-30 07:35:46
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-10-30 07:35:46
SC Data - All Services | Sending logon request message. | 2018-10-30 07:35:46
SC Data - All Services | Received logon response. | 2018-10-30 07:35:47
SC Data - All Services | Server Name: SC Realtime Server. | 2018-10-30 07:35:47
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-10-30 07:35:47
SC Data - All Services | Successfully connected. | 2018-10-30 07:35:47
SC Data - All Services | Trading is not supported. | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: AAPL -> AAPL | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: AMD -> AMD | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: AMZN -> AMZN | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: BABA -> BABA | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: CNET -> CNET | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: FB -> FB | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: GDX -> GDX | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: GE -> GE | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: GLD -> GLD | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: GOOG -> GOOG | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: HD -> HD | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: INTC -> INTC | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: JT -> JT | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: MSFT -> MSFT | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: NFLX -> NFLX | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: NVDA -> NVDA | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: PUTW -> PUTW | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: SLV -> SLV | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: SNAP -> SNAP | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: TSLA -> TSLA | 2018-10-30 07:35:47
SC Data - All Services | Restarting real-time data updates for symbol: ULTA -> ULTA | 2018-10-30 07:35:47
Symbol Error - $TNX is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol AAPL | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol AMD | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol AMZN | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol BABA | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol CNET | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol FB | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol GDX | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol GE | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol GLD | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol GOOG | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol HD | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol INTC | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol JT | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol MSFT | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol NFLX | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol NVDA | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol PUTW | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol SLV | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol SNAP | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol TSLA | 2018-10-30 07:35:47
SC Data - All Services | Received security definition for symbol ULTA | 2018-10-30 07:35:47
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 07:35:51
Socket (7) | Creating socket. | 2018-10-30 07:35:51
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 07:35:51
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 07:35:51
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 07:35:51
HD Server | HD Request #2 | Socket: 7 | Symbol: SNAP | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-29 23:57:29 | ClientRequestID: 2 | Username: jaytrader75. | 2018-10-30 07:35:51
Intraday data recording state for symbol SNAP is set to download 'Pending'. | 2018-10-30 07:35:51
HD Request # 7 | Downloading Intraday chart data for SNAP to the file SNAP.scid. Service: equities.us | 2018-10-30 07:35:51
HD Request # 7 | Download start date-time: 2018-10-29 19:57:29.000 | 2018-10-30 07:35:51
HD Request # 7 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 07:35:51
Socket (8) | Creating socket. | 2018-10-30 07:35:51
Socket (8) | Connecting to IP: 8.18.161.133. | 2018-10-30 07:35:51
HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-10-30 07:35:52
HD Request # 7 | Sending historical data logon request message. | 2018-10-30 07:35:52
HD Request # 7 | Requesting Intraday data. Start date-time: 2018-10-29 19:57:29. Record interval: 0. Symbol: SNAP | 2018-10-30 07:35:52
HD Request # 7 | Decompressing data. | 2018-10-30 07:35:52
HD Request # 7 | Receiving Intraday data for SNAP starting at 2018-10-29 19:57:29 | 2018-10-30 07:35:52
HD Request # 7 | Timestamp of first Intraday data file record written: 2018-10-30 04:18:51 | 2018-10-30 07:35:52
Socket (8) | Signaling to core to close socket | 2018-10-30 07:35:52
Socket (8) | Shutdown started. Waiting for graceful close. | 2018-10-30 07:35:52
Historical data download thread signaled to stop. | 2018-10-30 07:35:52
HD Request # 7 | Received 15 records from 2018-10-29 19:57:29 to 2018-10-30 07:10:52 (11.2 hours) and wrote 14 records for SNAP | 2018-10-30 07:35:52
HD Request # 7 | Completion time: 0s | 2018-10-30 07:35:52
HD Request # 7 | Intraday data download complete for SNAP. Unique request ID: 6 | 2018-10-30 07:35:52
Removed historical data download ID 6 | 2018-10-30 07:35:52
Real-time Intraday chart data file updates started for SNAP | 2018-10-30 07:35:52
Intraday chart data file opened for SNAP | 2018-10-30 07:35:52
Socket (8) | Socket gracefully closed by remote side. | 2018-10-30 07:35:52
Socket (8) | Closed. | 2018-10-30 07:35:52
HD Server | HD Request #2 | Socket: 7 | Symbol: SNAP | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 15 | ClientRequestID: 2 | Username: jaytrader75. | 2018-10-30 07:35:52
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 07:35:52
Socket (7) | Received socket Close event. | 2018-10-30 07:35:52
Socket (7) | Signaling to core to close socket | 2018-10-30 07:35:52
Socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:35:52
Socket (7) | Closed. | 2018-10-30 07:35:52
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 07:35:52
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 07:35:52
Socket (7) | Creating socket. | 2018-10-30 07:35:52
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 07:35:52
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 07:35:52
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 07:35:52
HD Server | HD Request #3 | Socket: 7 | Symbol: HSX18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 03:51:42 | ClientRequestID: 3 | Username: jaytrader75. | 2018-10-30 07:35:52
Intraday data recording state for symbol HSX18 is set to download 'Pending'. | 2018-10-30 07:35:52
HD Request # 8 | Downloading Intraday chart data for HSX18 to the file HSX18.scid. Service: HongKongFutures.Exchange | 2018-10-30 07:35:52
HD Request # 8 | Download start date-time: 2018-10-29 23:51:42.000 | 2018-10-30 07:35:52
HD Request # 8 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 07:35:52
Socket (8) | Creating socket. | 2018-10-30 07:35:52
Socket (8) | Connecting to IP: 8.18.161.135. | 2018-10-30 07:35:52
HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-10-30 07:35:53
HD Request # 8 | Sending historical data logon request message. | 2018-10-30 07:35:53
HD Request # 8 | Requesting Intraday data. Start date-time: 2018-10-29 23:51:42. Record interval: 0. Symbol: HSX18 | 2018-10-30 07:35:53
HD Request # 8 | Decompressing data. | 2018-10-30 07:35:53
HD Request # 8 | Receiving Intraday data for HSX18 starting at 2018-10-29 23:51:42 | 2018-10-30 07:35:53
HD Request # 8 | Timestamp of first Intraday data file record written: 2018-10-29 23:51:43 | 2018-10-30 07:35:53
Socket (8) | Signaling to core to close socket | 2018-10-30 07:35:53
Socket (8) | Shutdown started. Waiting for graceful close. | 2018-10-30 07:35:53
Historical data download thread signaled to stop. | 2018-10-30 07:35:53
HD Request # 8 | Received 104119 records from 2018-10-29 23:51:42 to 2018-10-30 07:35:48 (7.7 hours) and wrote 104117 records for HSX18 | 2018-10-30 07:35:53
HD Request # 8 | Completion time: 1s | 2018-10-30 07:35:53
HD Request # 8 | Intraday data download complete for HSX18. Unique request ID: 7 | 2018-10-30 07:35:53
Removed historical data download ID 7 | 2018-10-30 07:35:53
Real-time Intraday chart data file updates started for HSx18 | 2018-10-30 07:35:53
Intraday chart data file opened for HSx18 | 2018-10-30 07:35:53
Socket (8) | Socket gracefully closed by remote side. | 2018-10-30 07:35:53
Socket (8) | Closed. | 2018-10-30 07:35:53
HD Server | HD Request #3 | Socket: 7 | Symbol: HSX18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 104119 | ClientRequestID: 3 | Username: jaytrader75. | 2018-10-30 07:35:54
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 07:35:54
Socket (7) | Received socket Close event. | 2018-10-30 07:35:54
Socket (7) | Signaling to core to close socket | 2018-10-30 07:35:54
Socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:35:54
Socket (7) | Closed. | 2018-10-30 07:35:54
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 07:35:54
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 07:35:54
Socket (7) | Creating socket. | 2018-10-30 07:35:54
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 07:35:54
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 07:35:54
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 07:35:54
HD Server | HD Request #4 | Socket: 7 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 03:51:35 | ClientRequestID: 4 | Username: jaytrader75. | 2018-10-30 07:35:54
HD Server | HD Request #4 | Socket: 7 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 29124 | ClientRequestID: 4 | Username: jaytrader75. | 2018-10-30 07:35:54
Opened cached Intraday file: C:\SierraChart\Data\HSx18.scid | 2018-10-30 07:35:57
HTTPS historicaldata.sierrachart.com:443 (5) | Received socket Close event. | 2018-10-30 07:37:34
HTTPS historicaldata.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-10-30 07:37:34
HTTPS historicaldata.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-10-30 07:37:34
HTTPS historicaldata.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 07:37:34
HTTPS historicaldata.sierrachart.com:443 (5) | Closed. | 2018-10-30 07:37:34
Opened cached Intraday file: C:\SierraChart\Data\SNAP.scid | 2018-10-30 08:00:10
ESz18 [M] 10 Sec #3 | Reloading chart. | 2018-10-30 08:20:43
NQZ18 [M] 20 Sec #3 | Reloading chart. | 2018-10-30 08:34:17
Chart #3 has tagged chart #4 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:34:18
Chart #3 has tagged chart #6 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:34:18
Chart #3 has tagged chart #7 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:34:18
NQz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:34:18
NQz18 [M] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:34:18
NQz18 [CV] [M] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:34:18
NQZ18 [M] 2 Sec #3 | Reloading chart. | 2018-10-30 08:44:58
Chart #3 has tagged chart #4 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:44:59
Chart #3 has tagged chart #6 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:44:59
Chart #3 has tagged chart #7 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:44:59
NQz18 [CV] [M] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:44:59
NQz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:44:59
NQz18 [M] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 08:44:59
NQz18 [M] 2 Min #4 | Reloading chart. | 2018-10-30 09:37:03
GAIN Capital FAST Data socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-10-30 09:53:40 *
GAIN Capital FAST Data socket (2) | Socket gracefully closed by remote side. | 2018-10-30 09:53:40
GAIN Capital FAST Data socket (2) | Received socket Close event. | 2018-10-30 09:53:40
GAIN Capital FAST Data socket (2) | Signaling to core to close socket | 2018-10-30 09:53:40
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-10-30 09:53:40
GAIN Capital FAST Data socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 09:53:40
GAIN Capital FAST Data socket (2) | Closed. | 2018-10-30 09:53:40
Connection to the external service has been lost. | 2018-10-30 09:53:40
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-10-30 09:53:40
GAIN Capital FIX Trading: DisconnectFIX called. | 2018-10-30 09:53:40
GAIN Capital FIX Trading: Sending a Logout message. | 2018-10-30 09:53:40
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2018-10-30 09:53:40
GAIN Capital/OEC | Disconnected from the trading server. | 2018-10-30 09:53:40
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2018-10-30 09:53:40
GAIN Capital/OEC | Disconnected. | 2018-10-30 09:53:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-30 09:53:40
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2018-10-30 09:53:40
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:40
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2018-10-30 09:53:40
GAIN Capital FIX Trading socket (1) | Closed. | 2018-10-30 09:53:40
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-10-30 09:53:43
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2018-10-30 09:53:43
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2018-10-30 09:53:43
GAIN Capital FIX Trading: Sending the Logon message. | 2018-10-30 09:53:43
GAIN Capital FIX Trading | Connected to trading server. | 2018-10-30 09:53:44
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-10-30 09:53:44
GAIN Capital FAST Data socket (2) | Creating socket. | 2018-10-30 09:53:44
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2018-10-30 09:53:44
GAIN Capital FAST Data: Sent the Hello message. | 2018-10-30 09:53:44
GAIN Capital FAST Data: Sent the Logon message. | 2018-10-30 09:53:44
GAIN Capital/OEC | Connected to data and trading server. | 2018-10-30 09:53:44
DTC Client socket (4) | 64 bytes remaining in receive buffer when socket closed. | 2018-10-30 09:53:44
DTC Client socket (4) | Signaling to core to close socket | 2018-10-30 09:53:44
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:44
SC Data - All Services | Disconnected from the server. | 2018-10-30 09:53:44
DTC Client socket (6) | Signaling to core to close socket | 2018-10-30 09:53:44
DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:44
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 09:53:44
Mapping NQZ18 to NQZ18. Service code: cme | 2018-10-30 09:53:44
Socket (5) | Creating socket. | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: NQZ18. ID: 1 | 2018-10-30 09:53:44
SC Data - All Services | Using username 0 | 2018-10-30 09:53:44
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:44
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2018-10-30 09:53:44
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 09:53:44
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: NQZ18. ID: 1 | 2018-10-30 09:53:44
Intraday data recording state for symbol NQZ18 is set to download 'Pending'. | 2018-10-30 09:53:44
HD Server | HD Request #5 | Socket: 5 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 13:53:42 | ClientRequestID: 5 | Username: jaytrader75. | 2018-10-30 09:53:44
DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-10-30 09:53:44
DTC Client socket (4) | Closed. | 2018-10-30 09:53:44
Delaying start of download for NQZ18 | 2018-10-30 09:53:44
DTC Client socket (6) | Socket gracefully closed by remote side. | 2018-10-30 09:53:44
DTC Client socket (6) | Closed. | 2018-10-30 09:53:44
Mapping RTYz18 to RTYZ18. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: RTYZ18. ID: 2 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: RTYZ18. ID: 2 | 2018-10-30 09:53:44
Intraday data recording state for symbol RTYz18 is set to download 'Pending'. | 2018-10-30 09:53:44
Mapping YMZ18 to YMZ18. Service code: cbot | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: YMZ18. ID: 3 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: YMZ18. ID: 3 | 2018-10-30 09:53:44
Intraday data recording state for symbol YMz18 is set to download 'Pending'. | 2018-10-30 09:53:44
DTC Client socket (7) | Creating socket. | 2018-10-30 09:53:44
Historical Intraday data request for YMz18 is discarded because a matching download is already pending and the new one is not for earlier data. | 2018-10-30 09:53:44
DTC Client socket (7) | Connecting to IP: 8.18.161.133. | 2018-10-30 09:53:44
Mapping ESz18 to ESZ18. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: ESZ18. ID: 4 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: ESZ18. ID: 4 | 2018-10-30 09:53:44
Intraday data recording state for symbol ESz18 is set to download 'Pending'. | 2018-10-30 09:53:44
SC Data - All Services | Connected to server. | 2018-10-30 09:53:44
SC Data - All Services | Starting socket receive thread. | 2018-10-30 09:53:44
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-10-30 09:53:44
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:44
SC Data - All Services | Sending logon request message. | 2018-10-30 09:53:44
GAIN Capital/OEC | Starting real-time market data updates for: VXX18. ID: 5 | 2018-10-30 09:53:44
GAIN Capital/OEC | Requesting security definition data for: VXX18. ID: 5 | 2018-10-30 09:53:44
Mapping HSx18 to HSX18. Service code: HongKongFutures.Exchange | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: HSX18. ID: 6 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: HSX18. ID: 6 | 2018-10-30 09:53:44
Mapping GCLZ18 to CLZ18. Service code: nymex | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: CLZ18. ID: 7 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: CLZ18. ID: 7 | 2018-10-30 09:53:44
Mapping GGCZ18 to GCZ18. Service code: comex | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: GCZ18. ID: 8 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: GCZ18. ID: 8 | 2018-10-30 09:53:44
Mapping GHGZ18 to HGZ18. Service code: comex | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: HGZ18. ID: 9 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: HGZ18. ID: 9 | 2018-10-30 09:53:44
GAIN Capital/OEC | Starting real-time market data updates for: XBTX18. ID: 10 | 2018-10-30 09:53:44
GAIN Capital/OEC | Requesting security definition data for: XBTX18. ID: 10 | 2018-10-30 09:53:44
Mapping 6EZ18 to 6EZ18. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: 6EZ18. ID: 11 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: 6EZ18. ID: 11 | 2018-10-30 09:53:44
Mapping 6JZ18 to 6JZ18. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: 6JZ18. ID: 12 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: 6JZ18. ID: 12 | 2018-10-30 09:53:44
Mapping 6SZ18 to 6SZ18. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: 6SZ18. ID: 13 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: 6SZ18. ID: 13 | 2018-10-30 09:53:44
Mapping GEZ18 to GEZ18. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: GEZ18. ID: 14 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: GEZ18. ID: 14 | 2018-10-30 09:53:44
Mapping ZTZ18 to ZTZ18. Service code: cbot | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: ZTZ18. ID: 15 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: ZTZ18. ID: 15 | 2018-10-30 09:53:44
Mapping ZNZ18 to ZNZ18. Service code: cbot | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: ZNZ18. ID: 16 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: ZNZ18. ID: 16 | 2018-10-30 09:53:44
GAIN Capital/OEC | Starting real-time market data updates for: $TNX. ID: 17 | 2018-10-30 09:53:44
GAIN Capital/OEC | Requesting security definition data for: $TNX. ID: 17 | 2018-10-30 09:53:44
Mapping LBSF19 to LBSF19. Service code: cme | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: LBSF19. ID: 18 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: LBSF19. ID: 18 | 2018-10-30 09:53:44
Mapping ZCZ18 to ZCZ18. Service code: cbot | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: ZCZ18. ID: 19 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: ZCZ18. ID: 19 | 2018-10-30 09:53:44
Mapping ZSF19 to ZSF19. Service code: cbot | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: ZSF19. ID: 20 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: ZSF19. ID: 20 | 2018-10-30 09:53:44
Mapping GLD to GLD. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: GLD. ID: 21 | 2018-10-30 09:53:44
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: GLD. ID: 21 | 2018-10-30 09:53:44
Mapping SLV to SLV. Service code: equities.us | 2018-10-30 09:53:44
DTC Client socket (4) | Creating socket. | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: SLV. ID: 22 | 2018-10-30 09:53:44
DTC Client socket (4) | Connecting to IP: 8.18.161.133. | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: SLV. ID: 22 | 2018-10-30 09:53:44
Mapping FB to FB. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: FB. ID: 23 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: FB. ID: 23 | 2018-10-30 09:53:44
Mapping AMZN to AMZN. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: AMZN. ID: 24 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: AMZN. ID: 24 | 2018-10-30 09:53:44
Mapping GOOG to GOOG. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: GOOG. ID: 25 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: GOOG. ID: 25 | 2018-10-30 09:53:44
Mapping AAPL to AAPL. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: AAPL. ID: 26 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: AAPL. ID: 26 | 2018-10-30 09:53:44
Mapping NFLX to NFLX. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: NFLX. ID: 27 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: NFLX. ID: 27 | 2018-10-30 09:53:44
Mapping TSLA to TSLA. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: TSLA. ID: 28 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: TSLA. ID: 28 | 2018-10-30 09:53:44
Mapping BABA to BABA. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: BABA. ID: 29 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: BABA. ID: 29 | 2018-10-30 09:53:44
Mapping GDX to GDX. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: GDX. ID: 30 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: GDX. ID: 30 | 2018-10-30 09:53:44
Mapping PUTW to PUTW. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: PUTW. ID: 31 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: PUTW. ID: 31 | 2018-10-30 09:53:44
Mapping NVDA to NVDA. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: NVDA. ID: 32 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: NVDA. ID: 32 | 2018-10-30 09:53:44
Mapping INTC to INTC. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: INTC. ID: 33 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: INTC. ID: 33 | 2018-10-30 09:53:44
Mapping AMD to AMD. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: AMD. ID: 34 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: AMD. ID: 34 | 2018-10-30 09:53:44
Mapping JT to JT. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: JT. ID: 35 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: JT. ID: 35 | 2018-10-30 09:53:44
Mapping SNAP to SNAP. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: SNAP. ID: 36 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: SNAP. ID: 36 | 2018-10-30 09:53:44
Mapping GE to GE. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: GE. ID: 37 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: GE. ID: 37 | 2018-10-30 09:53:44
Mapping CNET to CNET. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: CNET. ID: 38 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: CNET. ID: 38 | 2018-10-30 09:53:44
Mapping MSFT to MSFT. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: MSFT. ID: 39 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: MSFT. ID: 39 | 2018-10-30 09:53:44
Mapping ULTA to ULTA. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: ULTA. ID: 40 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: ULTA. ID: 40 | 2018-10-30 09:53:44
Mapping HD to HD. Service code: equities.us | 2018-10-30 09:53:44
SC Data - All Services | Starting real-time market data updates for: HD. ID: 41 | 2018-10-30 09:53:44
SC Data - All Services | Requesting security definition data for: HD. ID: 41 | 2018-10-30 09:53:44
SC Data - All Services | Received logon response. | 2018-10-30 09:53:44
SC Data - All Services | Server Name: SC Realtime Server. | 2018-10-30 09:53:44
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-10-30 09:53:44
SC Data - All Services | Successfully connected. | 2018-10-30 09:53:44
SC Data - All Services | Trading is not supported. | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: 6EZ18 -> 6EZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: 6JZ18 -> 6JZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: 6SZ18 -> 6SZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: ESz18 -> ESZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GCLZ18 -> CLZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GEZ18 -> GEZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GGCZ18 -> GCZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GHGZ18 -> HGZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: HSx18 -> HSX18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: LBSF19 -> LBSF19 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: NQZ18 -> NQZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: RTYz18 -> RTYZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: YMZ18 -> YMZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: ZCZ18 -> ZCZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: ZNZ18 -> ZNZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: ZSF19 -> ZSF19 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: ZTZ18 -> ZTZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol 6EZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol 6JZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol 6SZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol ESz18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GCLZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GEZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GGCZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GHGZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol HSx18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol LBSF19 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol NQZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol RTYz18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol YMZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol ZCZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol ZNZ18 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol ZSF19 | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol ZTZ18 | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: AAPL -> AAPL | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: AMD -> AMD | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: AMZN -> AMZN | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: BABA -> BABA | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: CNET -> CNET | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: FB -> FB | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GDX -> GDX | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GE -> GE | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GLD -> GLD | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: GOOG -> GOOG | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: HD -> HD | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: INTC -> INTC | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: JT -> JT | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: MSFT -> MSFT | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: NFLX -> NFLX | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: NVDA -> NVDA | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: PUTW -> PUTW | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: SLV -> SLV | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: SNAP -> SNAP | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: TSLA -> TSLA | 2018-10-30 09:53:44
SC Data - All Services | Restarting real-time data updates for symbol: ULTA -> ULTA | 2018-10-30 09:53:44
Symbol Error - $TNX is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol AAPL | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol AMD | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol AMZN | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol BABA | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol CNET | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol FB | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GDX | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GE | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GLD | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol GOOG | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol HD | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol INTC | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol JT | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol MSFT | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol NFLX | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol NVDA | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol PUTW | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol SLV | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol SNAP | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol TSLA | 2018-10-30 09:53:44
SC Data - All Services | Received security definition for symbol ULTA | 2018-10-30 09:53:44
Requesting market depth updates for: ESz18 if supported. | 2018-10-30 09:53:49
Requesting market depth updates for: NQZ18 if supported. | 2018-10-30 09:53:49
Requesting market depth updates for: YMZ18 if supported. | 2018-10-30 09:53:49
SC Data - All Services | Clearing market depth for ESz18. | 2018-10-30 09:53:49
SC Data - All Services | Clearing market depth for NQZ18. | 2018-10-30 09:53:49
SC Data - All Services | Clearing market depth for YMZ18. | 2018-10-30 09:53:49
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 09:53:49
HD Request # 9 | Downloading Intraday chart data for NQZ18 to the file NQZ18.scid. Service: cme | 2018-10-30 09:53:50
HD Request # 9 | Download start date-time: 2018-10-30 09:53:42.000 | 2018-10-30 09:53:50
HD Request # 9 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 09:53:50
Socket (6) | Creating socket. | 2018-10-30 09:53:50
Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-30 09:53:50
HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:50
HD Request # 9 | Sending historical data logon request message. | 2018-10-30 09:53:50
HD Request # 9 | Requesting Intraday data. Start date-time: 2018-10-30 09:53:42. Record interval: 0. Symbol: NQZ18 | 2018-10-30 09:53:50
HD Request # 9 | Decompressing data. | 2018-10-30 09:53:50
HD Request # 9 | Receiving Intraday data for NQZ18 starting at 2018-10-30 09:53:42 | 2018-10-30 09:53:50
HD Request # 9 | Timestamp of first Intraday data file record written: 2018-10-30 09:53:43 | 2018-10-30 09:53:50
Socket (6) | Signaling to core to close socket | 2018-10-30 09:53:50
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:50
Historical data download thread signaled to stop. | 2018-10-30 09:53:50
HD Request # 9 | Received 128 records from 2018-10-30 09:53:42 to 2018-10-30 09:53:46 (4.0 seconds) and wrote 100 records for NQZ18 | 2018-10-30 09:53:50
Added 49 Time and Sales records to Intraday data file for NQZ18 after download. | 2018-10-30 09:53:50
HD Request # 9 | Completion time: 0s | 2018-10-30 09:53:50
HD Request # 9 | Intraday data download complete for NQZ18. Unique request ID: 8 | 2018-10-30 09:53:50
Removed historical data download ID 8 | 2018-10-30 09:53:50
Real-time Intraday chart data file updates started for NQZ18 | 2018-10-30 09:53:50
Intraday chart data file opened for NQZ18 | 2018-10-30 09:53:50
HD Request # 10 | Downloading Intraday chart data for YMZ18 to the file YMZ18.scid. Service: cbot | 2018-10-30 09:53:50
HD Request # 10 | Download start date-time: 2018-10-30 09:53:42.000 | 2018-10-30 09:53:50
HD Request # 10 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 09:53:50
Socket (8) | Creating socket. | 2018-10-30 09:53:50
Socket (8) | Connecting to IP: 8.18.161.135. | 2018-10-30 09:53:50
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 09:53:50
Socket (6) | Closed. | 2018-10-30 09:53:50
Chart #3 has tagged chart #4 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 09:53:50
Chart #3 has tagged chart #6 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 09:53:50
Chart #3 has tagged chart #7 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 09:53:50
HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:50
HD Request # 10 | Sending historical data logon request message. | 2018-10-30 09:53:50
NQz18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 09:53:50
HD Request # 10 | Requesting Intraday data. Start date-time: 2018-10-30 09:53:42. Record interval: 0. Symbol: YMZ18 | 2018-10-30 09:53:50
NQz18 [M] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 09:53:50
HD Request # 10 | Decompressing data. | 2018-10-30 09:53:50
HD Request # 10 | Receiving Intraday data for YMZ18 starting at 2018-10-30 09:53:42 | 2018-10-30 09:53:50
HD Request # 10 | Timestamp of first Intraday data file record written: 2018-10-30 09:53:42 | 2018-10-30 09:53:50
Socket (8) | Signaling to core to close socket | 2018-10-30 09:53:50
Socket (8) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:50
HD Request # 10 | Received 85 records from 2018-10-30 09:53:42 to 2018-10-30 09:53:48 (6.0 seconds) and wrote 79 records for YMZ18 | 2018-10-30 09:53:50
Added 4 Time and Sales records to Intraday data file for YMZ18 after download. | 2018-10-30 09:53:50
HD Request # 10 | Completion time: 1s | 2018-10-30 09:53:50
HD Request # 10 | Intraday data download complete for YMZ18. Unique request ID: 9 | 2018-10-30 09:53:50
Removed historical data download ID 9 | 2018-10-30 09:53:50
Real-time Intraday chart data file updates started for YMZ18 | 2018-10-30 09:53:50
Intraday chart data file opened for YMZ18 | 2018-10-30 09:53:50
HD Request # 11 | Downloading Intraday chart data for RTYz18 to the file RTYz18.scid. Service: cme | 2018-10-30 09:53:50
HD Request # 11 | Download start date-time: 2018-10-30 09:53:42.000 | 2018-10-30 09:53:50
HD Request # 11 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 09:53:50
NQz18 [CV] [M] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 09:53:50
Socket (8) | Socket gracefully closed by remote side. | 2018-10-30 09:53:50
Socket (8) | Closed. | 2018-10-30 09:53:50
Chart #11 has tagged chart #3 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 09:53:50
Chart #11 has tagged chart #4 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 09:53:50
Chart #11 has tagged chart #5 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 09:53:50
YMZ18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 09:53:50
YMZ18 [M] 5 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 09:53:50
HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:50
HD Request # 11 | Sending historical data logon request message. | 2018-10-30 09:53:50
NQZ18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 09:53:50
HD Request # 11 | Requesting Intraday data. Start date-time: 2018-10-30 09:53:42. Record interval: 0. Symbol: RTYZ18 | 2018-10-30 09:53:50
HD Request # 11 | Decompressing data. | 2018-10-30 09:53:50
HD Request # 11 | Receiving Intraday data for RTYz18 starting at 2018-10-30 09:53:42 | 2018-10-30 09:53:50
HD Request # 11 | Timestamp of first Intraday data file record written: 2018-10-30 09:53:43 | 2018-10-30 09:53:50
HD Request # 11 | Received 29 records from 2018-10-30 09:53:42 to 2018-10-30 09:53:45 (3.0 seconds) and wrote 22 records for RTYz18 | 2018-10-30 09:53:50
Added 9 Time and Sales records to Intraday data file for RTYz18 after download. | 2018-10-30 09:53:50
HD Request # 11 | Completion time: 0s | 2018-10-30 09:53:50
HD Request # 11 | Intraday data download complete for RTYz18. Unique request ID: 10 | 2018-10-30 09:53:50
Removed historical data download ID 10 | 2018-10-30 09:53:50
Real-time Intraday chart data file updates started for RTYz18 | 2018-10-30 09:53:50
Intraday chart data file opened for RTYz18 | 2018-10-30 09:53:50
HD Request # 12 | Downloading Intraday chart data for ESz18 to the file ESz18.scid. Service: cme | 2018-10-30 09:53:50
HD Request # 12 | Download start date-time: 2018-10-30 09:53:42.000 | 2018-10-30 09:53:50
HD Request # 12 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 09:53:50
Socket (6) | Connecting to IP: 8.18.161.135. | 2018-10-30 09:53:50
Chart #11 has tagged chart #3 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 09:53:50
Chart #11 has tagged chart #4 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 09:53:50
RTYz18 [M] 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 09:53:50
HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:50
HD Request # 12 | Sending historical data logon request message. | 2018-10-30 09:53:50
RTYz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 09:53:51
HD Request # 12 | Requesting Intraday data. Start date-time: 2018-10-30 09:53:42. Record interval: 0. Symbol: ESZ18 | 2018-10-30 09:53:51
HD Request # 12 | Decompressing data. | 2018-10-30 09:53:51
HD Request # 12 | Receiving Intraday data for ESz18 starting at 2018-10-30 09:53:42 | 2018-10-30 09:53:51
HD Request # 12 | Timestamp of first Intraday data file record written: 2018-10-30 09:53:43 | 2018-10-30 09:53:51
Socket (6) | Signaling to core to close socket | 2018-10-30 09:53:51
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:51
Historical data download thread signaled to stop. | 2018-10-30 09:53:51
HD Request # 12 | Received 335 records from 2018-10-30 09:53:42 to 2018-10-30 09:53:48 (6.0 seconds) and wrote 310 records for ESz18 | 2018-10-30 09:53:51
Added 17 Time and Sales records to Intraday data file for ESz18 after download. | 2018-10-30 09:53:51
HD Request # 12 | Completion time: 0s | 2018-10-30 09:53:51
HD Request # 12 | Intraday data download complete for ESz18. Unique request ID: 12 | 2018-10-30 09:53:51
Removed historical data download ID 12 | 2018-10-30 09:53:51
Real-time Intraday chart data file updates started for ESz18 | 2018-10-30 09:53:51
Intraday chart data file opened for ESz18 | 2018-10-30 09:53:51
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 09:53:51
Socket (6) | Closed. | 2018-10-30 09:53:51
Chart #11 has tagged chart #3 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 09:53:51
Chart #11 has tagged chart #4 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 09:53:51
Chart #11 has tagged chart #5 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 09:53:51
ESz18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 09:53:51
ESZ18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 09:53:51
ESz18 [M] 10 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 09:53:51
HD Server | HD Request #5 | Socket: 5 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 89 | ClientRequestID: 5 | Username: jaytrader75. | 2018-10-30 09:53:51
Socket (5) | Socket gracefully closed by remote side. | 2018-10-30 09:53:51
Socket (5) | Received socket Close event. | 2018-10-30 09:53:51
Socket (5) | Signaling to core to close socket | 2018-10-30 09:53:51
Socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 09:53:51
Socket (5) | Closed. | 2018-10-30 09:53:51
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 09:53:51
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 09:53:51
Socket (5) | Creating socket. | 2018-10-30 09:53:51
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:51
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 09:53:51
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 09:53:51
HD Server | HD Request #6 | Socket: 5 | Symbol: HSx18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 13:53:42 | ClientRequestID: 6 | Username: jaytrader75. | 2018-10-30 09:53:51
Intraday data recording state for symbol HSx18 is set to download 'Pending'. | 2018-10-30 09:53:51
HD Request # 13 | Downloading Intraday chart data for HSx18 to the file HSx18.scid. Service: HongKongFutures.Exchange | 2018-10-30 09:53:51
HD Request # 13 | Download start date-time: 2018-10-30 09:53:42.000 | 2018-10-30 09:53:51
HD Request # 13 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 09:53:51
Socket (6) | Creating socket. | 2018-10-30 09:53:51
Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-30 09:53:51
HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:51
HD Request # 13 | Sending historical data logon request message. | 2018-10-30 09:53:51
HD Request # 13 | Requesting Intraday data. Start date-time: 2018-10-30 09:53:42. Record interval: 0. Symbol: HSX18 | 2018-10-30 09:53:51
HD Request # 13 | Decompressing data. | 2018-10-30 09:53:51
HD Request # 13 | Receiving Intraday data for HSx18 starting at 2018-10-30 09:53:42 | 2018-10-30 09:53:51
HD Request # 13 | Timestamp of first Intraday data file record written: 2018-10-30 09:53:43 | 2018-10-30 09:53:51
HD Request # 13 | Received 16 records from 2018-10-30 09:53:42 to 2018-10-30 09:53:46 (4.0 seconds) and wrote 10 records for HSx18 | 2018-10-30 09:53:51
Added 22 Time and Sales records to Intraday data file for HSx18 after download. | 2018-10-30 09:53:51
HD Request # 13 | Completion time: 0s | 2018-10-30 09:53:51
HD Request # 13 | Intraday data download complete for HSx18. Unique request ID: 13 | 2018-10-30 09:53:51
Removed historical data download ID 13 | 2018-10-30 09:53:51
Real-time Intraday chart data file updates started for HSx18 | 2018-10-30 09:53:51
Intraday chart data file opened for HSx18 | 2018-10-30 09:53:51
Opened cached Intraday file: C:\SierraChart\Data\NQZ18.scid | 2018-10-30 09:53:52
Opened cached Intraday file: C:\SierraChart\Data\RTYz18.scid | 2018-10-30 09:53:52
Opened cached Intraday file: C:\SierraChart\Data\YMZ18.scid | 2018-10-30 09:53:52
Opened cached Intraday file: C:\SierraChart\Data\ESz18.scid | 2018-10-30 09:53:52
Socket (5) | Socket gracefully closed by remote side. | 2018-10-30 09:53:52
Socket (5) | Received socket Close event. | 2018-10-30 09:53:52
HD Server | HD Request #6 | Socket: 5 | Symbol: HSx18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 38 | ClientRequestID: 6 | Username: jaytrader75. | 2018-10-30 09:53:52
Socket (5) | Signaling to core to close socket | 2018-10-30 09:53:52
Socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 09:53:52
Socket (5) | Closed. | 2018-10-30 09:53:52
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 09:53:52
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 09:53:52
Socket (5) | Creating socket. | 2018-10-30 09:53:52
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:52
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 09:53:52
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 09:53:52
HD Server | HD Request #7 | Socket: 5 | Symbol: SNAP | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 13:53:41 | ClientRequestID: 7 | Username: jaytrader75. | 2018-10-30 09:53:52
Intraday data recording state for symbol SNAP is set to download 'Pending'. | 2018-10-30 09:53:52
HD Request # 14 | Downloading Intraday chart data for SNAP to the file SNAP.scid. Service: equities.us | 2018-10-30 09:53:52
HD Request # 14 | Download start date-time: 2018-10-30 09:53:41.000 | 2018-10-30 09:53:52
HD Request # 14 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 09:53:52
Socket (6) | Creating socket. | 2018-10-30 09:53:52
Socket (6) | Connecting to IP: 8.18.161.135. | 2018-10-30 09:53:52
HD Request # 14 | Setting DTC encoding to Binary VLS | 2018-10-30 09:53:52
HD Request # 14 | Sending historical data logon request message. | 2018-10-30 09:53:52
HD Request # 14 | Requesting Intraday data. Start date-time: 2018-10-30 09:53:41. Record interval: 0. Symbol: SNAP | 2018-10-30 09:53:52
HD Request # 14 | Decompressing data. | 2018-10-30 09:53:52
HD Request # 14 | Receiving Intraday data for SNAP starting at 2018-10-30 09:53:41 | 2018-10-30 09:53:52
HD Request # 14 | Timestamp of first Intraday data file record written: 2018-10-30 09:53:42 | 2018-10-30 09:53:52
Socket (6) | Signaling to core to close socket | 2018-10-30 09:53:52
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 09:53:52
Historical data download thread signaled to stop. | 2018-10-30 09:53:52
HD Request # 14 | Received 40 records from 2018-10-30 09:53:41 to 2018-10-30 09:53:48 (7.0 seconds) and wrote 37 records for SNAP | 2018-10-30 09:53:52
Added 1 Time and Sales records to Intraday data file for SNAP after download. | 2018-10-30 09:53:52
HD Request # 14 | Completion time: 0s | 2018-10-30 09:53:52
HD Request # 14 | Intraday data download complete for SNAP. Unique request ID: 14 | 2018-10-30 09:53:52
Removed historical data download ID 14 | 2018-10-30 09:53:52
Real-time Intraday chart data file updates started for SNAP | 2018-10-30 09:53:52
Intraday chart data file opened for SNAP | 2018-10-30 09:53:52
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 09:53:53
Socket (6) | Closed. | 2018-10-30 09:53:53
HD Server | HD Request #7 | Socket: 5 | Symbol: SNAP | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 41 | ClientRequestID: 7 | Username: jaytrader75. | 2018-10-30 09:53:53
Socket (5) | Socket gracefully closed by remote side. | 2018-10-30 09:53:53
Socket (5) | Received socket Close event. | 2018-10-30 09:53:53
Socket (5) | Signaling to core to close socket | 2018-10-30 09:53:53
Socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 09:53:53
Socket (5) | Closed. | 2018-10-30 09:53:53
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 09:53:53
Opened cached Intraday file: C:\SierraChart\Data\HSx18.scid | 2018-10-30 09:53:55
Opened cached Intraday file: C:\SierraChart\Data\SNAP.scid | 2018-10-30 09:53:55
GAIN Capital FAST Data socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-10-30 10:37:45 *
GAIN Capital FAST Data socket (2) | Socket gracefully closed by remote side. | 2018-10-30 10:37:45
GAIN Capital FAST Data socket (2) | Received socket Close event. | 2018-10-30 10:37:45
GAIN Capital FAST Data socket (2) | Signaling to core to close socket | 2018-10-30 10:37:45
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-10-30 10:37:45
GAIN Capital FAST Data socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 10:37:45
GAIN Capital FAST Data socket (2) | Closed. | 2018-10-30 10:37:45
Connection to the external service has been lost. | 2018-10-30 10:37:45
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-10-30 10:37:45
GAIN Capital FIX Trading: DisconnectFIX called. | 2018-10-30 10:37:45
GAIN Capital FIX Trading: Sending a Logout message. | 2018-10-30 10:37:45
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2018-10-30 10:37:45
GAIN Capital/OEC | Disconnected from the trading server. | 2018-10-30 10:37:45
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2018-10-30 10:37:45
GAIN Capital/OEC | Disconnected. | 2018-10-30 10:37:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-30 10:37:45
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2018-10-30 10:37:45
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:45
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2018-10-30 10:37:45
GAIN Capital FIX Trading socket (1) | Closed. | 2018-10-30 10:37:45
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-10-30 10:37:48
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2018-10-30 10:37:48
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2018-10-30 10:37:48
GAIN Capital FIX Trading: Sending the Logon message. | 2018-10-30 10:37:48
GAIN Capital FIX Trading | Connected to trading server. | 2018-10-30 10:37:48
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-10-30 10:37:48
GAIN Capital FAST Data socket (2) | Creating socket. | 2018-10-30 10:37:48
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2018-10-30 10:37:48
GAIN Capital FAST Data: Sent the Hello message. | 2018-10-30 10:37:48
GAIN Capital FAST Data: Sent the Logon message. | 2018-10-30 10:37:49
GAIN Capital/OEC | Connected to data and trading server. | 2018-10-30 10:37:49
DTC Client socket (7) | Signaling to core to close socket | 2018-10-30 10:37:49
DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:49
SC Data - All Services | Disconnected from the server. | 2018-10-30 10:37:49
DTC Client socket (4) | Signaling to core to close socket | 2018-10-30 10:37:49
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:49
Mapping RTYz18 to RTYZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: RTYZ18. ID: 1 | 2018-10-30 10:37:49
SC Data - All Services | Using username 0 | 2018-10-30 10:37:49
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: RTYZ18. ID: 1 | 2018-10-30 10:37:49
Intraday data recording state for symbol RTYz18 is set to download 'Pending'. | 2018-10-30 10:37:49
Delaying start of download for RTYz18 | 2018-10-30 10:37:49
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 10:37:49
Socket (6) | Creating socket. | 2018-10-30 10:37:49
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:49
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 10:37:49
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 10:37:49
HD Server | HD Request #8 | Socket: 6 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 14:37:47 | ClientRequestID: 8 | Username: jaytrader75. | 2018-10-30 10:37:49
Mapping YMz18 to YMZ18. Service code: cbot | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: YMZ18. ID: 2 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: YMZ18. ID: 2 | 2018-10-30 10:37:49
Intraday data recording state for symbol YMz18 is set to download 'Pending'. | 2018-10-30 10:37:49
Historical Intraday data request for YMz18 is discarded because a matching download is already pending and the new one is not for earlier data. | 2018-10-30 10:37:49
Mapping NQz18 to NQZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: NQZ18. ID: 3 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: NQZ18. ID: 3 | 2018-10-30 10:37:49
Intraday data recording state for symbol NQz18 is set to download 'Pending'. | 2018-10-30 10:37:49
DTC Client socket (7) | Socket gracefully closed by remote side. | 2018-10-30 10:37:49
DTC Client socket (7) | Closed. | 2018-10-30 10:37:49
DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-10-30 10:37:49
DTC Client socket (4) | Closed. | 2018-10-30 10:37:49
Mapping ESz18 to ESZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: ESZ18. ID: 4 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: ESZ18. ID: 4 | 2018-10-30 10:37:49
Intraday data recording state for symbol ESz18 is set to download 'Pending'. | 2018-10-30 10:37:49
DTC Client socket (5) | Creating socket. | 2018-10-30 10:37:49
DTC Client socket (5) | Connecting to IP: 8.18.161.135. | 2018-10-30 10:37:49
SC Data - All Services | Connected to server. | 2018-10-30 10:37:49
SC Data - All Services | Starting socket receive thread. | 2018-10-30 10:37:49
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-10-30 10:37:49
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:49
SC Data - All Services | Sending logon request message. | 2018-10-30 10:37:49
GAIN Capital/OEC | Starting real-time market data updates for: VXX18. ID: 5 | 2018-10-30 10:37:49
GAIN Capital/OEC | Requesting security definition data for: VXX18. ID: 5 | 2018-10-30 10:37:49
Mapping HSx18 to HSX18. Service code: HongKongFutures.Exchange | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: HSX18. ID: 6 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: HSX18. ID: 6 | 2018-10-30 10:37:49
Mapping GCLZ18 to CLZ18. Service code: nymex | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: CLZ18. ID: 7 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: CLZ18. ID: 7 | 2018-10-30 10:37:49
Mapping GGCZ18 to GCZ18. Service code: comex | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: GCZ18. ID: 8 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: GCZ18. ID: 8 | 2018-10-30 10:37:49
Mapping GHGZ18 to HGZ18. Service code: comex | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: HGZ18. ID: 9 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: HGZ18. ID: 9 | 2018-10-30 10:37:49
GAIN Capital/OEC | Starting real-time market data updates for: XBTX18. ID: 10 | 2018-10-30 10:37:49
GAIN Capital/OEC | Requesting security definition data for: XBTX18. ID: 10 | 2018-10-30 10:37:49
Mapping 6EZ18 to 6EZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: 6EZ18. ID: 11 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: 6EZ18. ID: 11 | 2018-10-30 10:37:49
Mapping 6JZ18 to 6JZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: 6JZ18. ID: 12 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: 6JZ18. ID: 12 | 2018-10-30 10:37:49
Mapping 6SZ18 to 6SZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: 6SZ18. ID: 13 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: 6SZ18. ID: 13 | 2018-10-30 10:37:49
Mapping GEZ18 to GEZ18. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: GEZ18. ID: 14 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: GEZ18. ID: 14 | 2018-10-30 10:37:49
Mapping ZTZ18 to ZTZ18. Service code: cbot | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: ZTZ18. ID: 15 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: ZTZ18. ID: 15 | 2018-10-30 10:37:49
Mapping ZNZ18 to ZNZ18. Service code: cbot | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: ZNZ18. ID: 16 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: ZNZ18. ID: 16 | 2018-10-30 10:37:49
GAIN Capital/OEC | Starting real-time market data updates for: $TNX. ID: 17 | 2018-10-30 10:37:49
GAIN Capital/OEC | Requesting security definition data for: $TNX. ID: 17 | 2018-10-30 10:37:49
Mapping LBSF19 to LBSF19. Service code: cme | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: LBSF19. ID: 18 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: LBSF19. ID: 18 | 2018-10-30 10:37:49
Mapping ZCZ18 to ZCZ18. Service code: cbot | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: ZCZ18. ID: 19 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: ZCZ18. ID: 19 | 2018-10-30 10:37:49
Mapping ZSF19 to ZSF19. Service code: cbot | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: ZSF19. ID: 20 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: ZSF19. ID: 20 | 2018-10-30 10:37:49
Mapping GLD to GLD. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: GLD. ID: 21 | 2018-10-30 10:37:49
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: GLD. ID: 21 | 2018-10-30 10:37:49
Mapping SLV to SLV. Service code: equities.us | 2018-10-30 10:37:49
DTC Client socket (4) | Creating socket. | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: SLV. ID: 22 | 2018-10-30 10:37:49
DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: SLV. ID: 22 | 2018-10-30 10:37:49
Mapping FB to FB. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: FB. ID: 23 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: FB. ID: 23 | 2018-10-30 10:37:49
Mapping AMZN to AMZN. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: AMZN. ID: 24 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: AMZN. ID: 24 | 2018-10-30 10:37:49
Mapping GOOG to GOOG. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: GOOG. ID: 25 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: GOOG. ID: 25 | 2018-10-30 10:37:49
Mapping AAPL to AAPL. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: AAPL. ID: 26 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: AAPL. ID: 26 | 2018-10-30 10:37:49
Mapping NFLX to NFLX. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: NFLX. ID: 27 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: NFLX. ID: 27 | 2018-10-30 10:37:49
Mapping TSLA to TSLA. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: TSLA. ID: 28 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: TSLA. ID: 28 | 2018-10-30 10:37:49
Mapping BABA to BABA. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: BABA. ID: 29 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: BABA. ID: 29 | 2018-10-30 10:37:49
Mapping GDX to GDX. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: GDX. ID: 30 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: GDX. ID: 30 | 2018-10-30 10:37:49
Mapping PUTW to PUTW. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: PUTW. ID: 31 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: PUTW. ID: 31 | 2018-10-30 10:37:49
Mapping NVDA to NVDA. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: NVDA. ID: 32 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: NVDA. ID: 32 | 2018-10-30 10:37:49
Mapping INTC to INTC. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: INTC. ID: 33 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: INTC. ID: 33 | 2018-10-30 10:37:49
Mapping AMD to AMD. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: AMD. ID: 34 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: AMD. ID: 34 | 2018-10-30 10:37:49
Mapping JT to JT. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: JT. ID: 35 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: JT. ID: 35 | 2018-10-30 10:37:49
Mapping SNAP to SNAP. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: SNAP. ID: 36 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: SNAP. ID: 36 | 2018-10-30 10:37:49
Mapping GE to GE. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: GE. ID: 37 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: GE. ID: 37 | 2018-10-30 10:37:49
Mapping CNET to CNET. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: CNET. ID: 38 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: CNET. ID: 38 | 2018-10-30 10:37:49
Mapping MSFT to MSFT. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: MSFT. ID: 39 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: MSFT. ID: 39 | 2018-10-30 10:37:49
Mapping ULTA to ULTA. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: ULTA. ID: 40 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: ULTA. ID: 40 | 2018-10-30 10:37:49
Mapping HD to HD. Service code: equities.us | 2018-10-30 10:37:49
SC Data - All Services | Starting real-time market data updates for: HD. ID: 41 | 2018-10-30 10:37:49
SC Data - All Services | Requesting security definition data for: HD. ID: 41 | 2018-10-30 10:37:49
SC Data - All Services | Received logon response. | 2018-10-30 10:37:49
SC Data - All Services | Server Name: SC Realtime Server. | 2018-10-30 10:37:49
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-10-30 10:37:49
SC Data - All Services | Successfully connected. | 2018-10-30 10:37:49
SC Data - All Services | Trading is not supported. | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: 6EZ18 -> 6EZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: 6JZ18 -> 6JZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: 6SZ18 -> 6SZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: ESz18 -> ESZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GCLZ18 -> CLZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GEZ18 -> GEZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GGCZ18 -> GCZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GHGZ18 -> HGZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: HSx18 -> HSX18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: LBSF19 -> LBSF19 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: NQz18 -> NQZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: RTYz18 -> RTYZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: YMz18 -> YMZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: ZCZ18 -> ZCZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: ZNZ18 -> ZNZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: ZSF19 -> ZSF19 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: ZTZ18 -> ZTZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol 6EZ18 | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: AAPL -> AAPL | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: AMD -> AMD | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: AMZN -> AMZN | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: BABA -> BABA | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: CNET -> CNET | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: FB -> FB | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GDX -> GDX | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GE -> GE | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GLD -> GLD | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: GOOG -> GOOG | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: HD -> HD | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: INTC -> INTC | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: JT -> JT | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: MSFT -> MSFT | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: NFLX -> NFLX | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: NVDA -> NVDA | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: PUTW -> PUTW | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: SLV -> SLV | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: SNAP -> SNAP | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: TSLA -> TSLA | 2018-10-30 10:37:49
SC Data - All Services | Restarting real-time data updates for symbol: ULTA -> ULTA | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol 6JZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol 6SZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol ESz18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GCLZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GEZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GGCZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GHGZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol HSx18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol LBSF19 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol NQz18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol RTYz18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol YMz18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol ZCZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol ZNZ18 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol ZSF19 | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol ZTZ18 | 2018-10-30 10:37:49
Symbol Error - $TNX is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol AAPL | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol AMD | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol AMZN | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol BABA | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol CNET | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol FB | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GDX | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GE | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GLD | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol GOOG | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol HD | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol INTC | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol JT | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol MSFT | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol NFLX | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol NVDA | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol PUTW | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol SLV | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol SNAP | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol TSLA | 2018-10-30 10:37:49
SC Data - All Services | Received security definition for symbol ULTA | 2018-10-30 10:37:49
Requesting market depth updates for: ESz18 if supported. | 2018-10-30 10:37:54
Requesting market depth updates for: NQz18 if supported. | 2018-10-30 10:37:54
Requesting market depth updates for: YMz18 if supported. | 2018-10-30 10:37:54
SC Data - All Services | Clearing market depth for ESz18. | 2018-10-30 10:37:54
SC Data - All Services | Clearing market depth for NQz18. | 2018-10-30 10:37:54
SC Data - All Services | Clearing market depth for YMz18. | 2018-10-30 10:37:54
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 10:37:54
HD Request # 15 | Downloading Intraday chart data for RTYz18 to the file RTYz18.scid. Service: cme | 2018-10-30 10:37:55
HD Request # 15 | Download start date-time: 2018-10-30 10:37:47.000 | 2018-10-30 10:37:55
HD Request # 15 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 10:37:55
Socket (7) | Creating socket. | 2018-10-30 10:37:55
Socket (7) | Connecting to IP: 8.18.161.133. | 2018-10-30 10:37:55
HD Request # 15 | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:55
HD Request # 15 | Sending historical data logon request message. | 2018-10-30 10:37:55
HD Request # 15 | Requesting Intraday data. Start date-time: 2018-10-30 10:37:47. Record interval: 0. Symbol: RTYZ18 | 2018-10-30 10:37:55
HD Request # 15 | Decompressing data. | 2018-10-30 10:37:55
HD Request # 15 | Receiving Intraday data for RTYz18 starting at 2018-10-30 10:37:47 | 2018-10-30 10:37:55
HD Request # 15 | Timestamp of first Intraday data file record written: 2018-10-30 10:37:47 | 2018-10-30 10:37:55
Socket (7) | Signaling to core to close socket | 2018-10-30 10:37:55
Socket (7) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:55
Historical data download thread signaled to stop. | 2018-10-30 10:37:55
HD Request # 15 | Received 43 records from 2018-10-30 10:37:47 to 2018-10-30 10:37:52 (5.0 seconds) and wrote 40 records for RTYz18 | 2018-10-30 10:37:55
Added 16 Time and Sales records to Intraday data file for RTYz18 after download. | 2018-10-30 10:37:55
HD Request # 15 | Completion time: 1s | 2018-10-30 10:37:55
HD Request # 15 | Intraday data download complete for RTYz18. Unique request ID: 15 | 2018-10-30 10:37:55
Removed historical data download ID 15 | 2018-10-30 10:37:55
Real-time Intraday chart data file updates started for RTYz18 | 2018-10-30 10:37:55
Intraday chart data file opened for RTYz18 | 2018-10-30 10:37:55
HD Request # 16 | Downloading Intraday chart data for YMZ18 to the file YMZ18.scid. Service: cbot | 2018-10-30 10:37:55
HD Request # 16 | Download start date-time: 2018-10-30 10:37:47.000 | 2018-10-30 10:37:55
HD Request # 16 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 10:37:55
Socket (8) | Creating socket. | 2018-10-30 10:37:55
Socket (8) | Connecting to IP: 8.18.161.135. | 2018-10-30 10:37:55
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 10:37:55
Socket (7) | Closed. | 2018-10-30 10:37:55
Chart #11 has tagged chart #3 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 10:37:55
Chart #11 has tagged chart #4 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 10:37:55
RTYz18 [M] 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 10:37:55
HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:55
HD Request # 16 | Sending historical data logon request message. | 2018-10-30 10:37:55
RTYz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 10:37:55
HD Request # 16 | Requesting Intraday data. Start date-time: 2018-10-30 10:37:47. Record interval: 0. Symbol: YMZ18 | 2018-10-30 10:37:55
HD Request # 16 | Decompressing data. | 2018-10-30 10:37:55
HD Request # 16 | Receiving Intraday data for YMZ18 starting at 2018-10-30 10:37:47 | 2018-10-30 10:37:55
HD Request # 16 | Timestamp of first Intraday data file record written: 2018-10-30 10:37:47 | 2018-10-30 10:37:55
Socket (8) | Signaling to core to close socket | 2018-10-30 10:37:55
Socket (8) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:55
HD Request # 16 | Received 131 records from 2018-10-30 10:37:47 to 2018-10-30 10:37:52 (5.0 seconds) and wrote 128 records for YMZ18 | 2018-10-30 10:37:55
Added 19 Time and Sales records to Intraday data file for YMz18 after download. | 2018-10-30 10:37:55
HD Request # 16 | Completion time: 0s | 2018-10-30 10:37:55
HD Request # 16 | Intraday data download complete for YMZ18. Unique request ID: 16 | 2018-10-30 10:37:55
Removed historical data download ID 16 | 2018-10-30 10:37:55
Real-time Intraday chart data file updates started for YMz18 | 2018-10-30 10:37:55
Intraday chart data file opened for YMz18 | 2018-10-30 10:37:55
HD Request # 17 | Downloading Intraday chart data for NQz18 to the file NQz18.scid. Service: cme | 2018-10-30 10:37:55
HD Request # 17 | Download start date-time: 2018-10-30 10:37:47.000 | 2018-10-30 10:37:55
HD Request # 17 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 10:37:55
Socket (8) | Socket gracefully closed by remote side. | 2018-10-30 10:37:55
Socket (8) | Closed. | 2018-10-30 10:37:55
Chart #11 has tagged chart #3 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 10:37:55
Chart #11 has tagged chart #4 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 10:37:55
Chart #11 has tagged chart #5 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 10:37:55
HD Request # 17 | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:55
HD Request # 17 | Sending historical data logon request message. | 2018-10-30 10:37:55
YMZ18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 10:37:55
YMZ18 [M] 5 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 10:37:55
HD Request # 17 | Requesting Intraday data. Start date-time: 2018-10-30 10:37:47. Record interval: 0. Symbol: NQZ18 | 2018-10-30 10:37:55
NQZ18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 10:37:55
HD Request # 17 | Decompressing data. | 2018-10-30 10:37:55
HD Request # 17 | Receiving Intraday data for NQz18 starting at 2018-10-30 10:37:47 | 2018-10-30 10:37:55
HD Request # 17 | Timestamp of first Intraday data file record written: 2018-10-30 10:37:47 | 2018-10-30 10:37:55
Historical data download thread signaled to stop. | 2018-10-30 10:37:56
HD Request # 17 | Received 181 records from 2018-10-30 10:37:47 to 2018-10-30 10:37:52 (5.0 seconds) and wrote 171 records for NQz18 | 2018-10-30 10:37:56
Added 60 Time and Sales records to Intraday data file for NQz18 after download. | 2018-10-30 10:37:56
HD Request # 17 | Completion time: 0s | 2018-10-30 10:37:56
HD Request # 17 | Intraday data download complete for NQz18. Unique request ID: 18 | 2018-10-30 10:37:56
Removed historical data download ID 18 | 2018-10-30 10:37:56
Real-time Intraday chart data file updates started for NQz18 | 2018-10-30 10:37:56
Intraday chart data file opened for NQz18 | 2018-10-30 10:37:56
HD Request # 18 | Downloading Intraday chart data for ESz18 to the file ESz18.scid. Service: cme | 2018-10-30 10:37:56
HD Request # 18 | Download start date-time: 2018-10-30 10:37:47.000 | 2018-10-30 10:37:56
HD Request # 18 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 10:37:56
Socket (7) | Creating socket. | 2018-10-30 10:37:56
Socket (7) | Connecting to IP: 8.18.161.135. | 2018-10-30 10:37:56
HD Server | HD Request #8 | Socket: 6 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 150 | ClientRequestID: 8 | Username: jaytrader75. | 2018-10-30 10:37:56
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 10:37:56
Socket (6) | Received socket Close event. | 2018-10-30 10:37:56
Socket (6) | Signaling to core to close socket | 2018-10-30 10:37:56
Socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 10:37:56
Socket (6) | Closed. | 2018-10-30 10:37:56
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 10:37:56
HD Request # 18 | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:56
HD Request # 18 | Sending historical data logon request message. | 2018-10-30 10:37:56
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 10:37:56
Socket (6) | Creating socket. | 2018-10-30 10:37:56
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:56
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 10:37:56
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 10:37:56
HD Server | HD Request #9 | Socket: 6 | Symbol: HSx18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 14:37:47 | ClientRequestID: 9 | Username: jaytrader75. | 2018-10-30 10:37:56
Intraday data recording state for symbol HSx18 is set to download 'Pending'. | 2018-10-30 10:37:56
Opened cached Intraday file: C:\SierraChart\Data\RTYz18.scid | 2018-10-30 10:37:56
Opened cached Intraday file: C:\SierraChart\Data\YMz18.scid | 2018-10-30 10:37:56
Opened cached Intraday file: C:\SierraChart\Data\NQz18.scid | 2018-10-30 10:37:56
HD Request # 18 | Requesting Intraday data. Start date-time: 2018-10-30 10:37:47. Record interval: 0. Symbol: ESZ18 | 2018-10-30 10:37:56
Chart #3 has tagged chart #4 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 10:37:56
Chart #3 has tagged chart #6 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 10:37:56
Chart #3 has tagged chart #7 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 10:37:56
HD Request # 18 | Decompressing data. | 2018-10-30 10:37:56
HD Request # 18 | Receiving Intraday data for ESz18 starting at 2018-10-30 10:37:47 | 2018-10-30 10:37:56
HD Request # 18 | Timestamp of first Intraday data file record written: 2018-10-30 10:37:47 | 2018-10-30 10:37:56
Socket (7) | Signaling to core to close socket | 2018-10-30 10:37:56
Socket (7) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:56
HD Request # 18 | Received 248 records from 2018-10-30 10:37:47 to 2018-10-30 10:37:52 (5.1 seconds) and wrote 220 records for ESz18 | 2018-10-30 10:37:56
Added 65 Time and Sales records to Intraday data file for ESz18 after download. | 2018-10-30 10:37:56
HD Request # 18 | Completion time: 0s | 2018-10-30 10:37:56
HD Request # 18 | Intraday data download complete for ESz18. Unique request ID: 19 | 2018-10-30 10:37:56
Removed historical data download ID 19 | 2018-10-30 10:37:56
Real-time Intraday chart data file updates started for ESz18 | 2018-10-30 10:37:56
Intraday chart data file opened for ESz18 | 2018-10-30 10:37:56
HD Request # 19 | Downloading Intraday chart data for HSx18 to the file HSx18.scid. Service: HongKongFutures.Exchange | 2018-10-30 10:37:56
HD Request # 19 | Download start date-time: 2018-10-30 10:37:47.000 | 2018-10-30 10:37:56
HD Request # 19 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 10:37:56
Socket (8) | Creating socket. | 2018-10-30 10:37:56
Socket (8) | Connecting to IP: 8.18.161.133. | 2018-10-30 10:37:56
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 10:37:56
Socket (7) | Closed. | 2018-10-30 10:37:56
Chart #11 has tagged chart #3 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 10:37:56
Chart #11 has tagged chart #4 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 10:37:56
Chart #11 has tagged chart #5 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 10:37:56
NQz18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 10:37:56
NQz18 [M] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 10:37:56
HD Request # 19 | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:56
HD Request # 19 | Sending historical data logon request message. | 2018-10-30 10:37:56
ESz18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 10:37:56
HD Request # 19 | Requesting Intraday data. Start date-time: 2018-10-30 10:37:47. Record interval: 0. Symbol: HSX18 | 2018-10-30 10:37:56
NQz18 [CV] [M] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 10:37:56
HD Request # 19 | Decompressing data. | 2018-10-30 10:37:56
HD Request # 19 | Receiving Intraday data for HSx18 starting at 2018-10-30 10:37:47 | 2018-10-30 10:37:56
HD Request # 19 | Timestamp of first Intraday data file record written: 2018-10-30 10:37:47 | 2018-10-30 10:37:56
Socket (8) | Signaling to core to close socket | 2018-10-30 10:37:56
Socket (8) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:56
HD Request # 19 | Received 91 records from 2018-10-30 10:37:47 to 2018-10-30 10:37:54 (7.0 seconds) and wrote 85 records for HSx18 | 2018-10-30 10:37:56
Added 2 Time and Sales records to Intraday data file for HSx18 after download. | 2018-10-30 10:37:56
HD Request # 19 | Completion time: 0s | 2018-10-30 10:37:56
HD Request # 19 | Intraday data download complete for HSx18. Unique request ID: 20 | 2018-10-30 10:37:56
Removed historical data download ID 20 | 2018-10-30 10:37:56
Real-time Intraday chart data file updates started for HSx18 | 2018-10-30 10:37:56
Intraday chart data file opened for HSx18 | 2018-10-30 10:37:56
ESZ18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 10:37:56
ESz18 [M] 10 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 10:37:56
Socket (8) | Socket gracefully closed by remote side. | 2018-10-30 10:37:56
Socket (8) | Closed. | 2018-10-30 10:37:56
HD Server | HD Request #9 | Socket: 6 | Symbol: HSx18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 93 | ClientRequestID: 9 | Username: jaytrader75. | 2018-10-30 10:37:57
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 10:37:57
Socket (6) | Received socket Close event. | 2018-10-30 10:37:57
Socket (6) | Signaling to core to close socket | 2018-10-30 10:37:57
Socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 10:37:57
Socket (6) | Closed. | 2018-10-30 10:37:57
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 10:37:57
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 10:37:57
Socket (6) | Creating socket. | 2018-10-30 10:37:57
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:57
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 10:37:57
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 10:37:57
HD Server | HD Request #10 | Socket: 6 | Symbol: SNAP | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 14:37:44 | ClientRequestID: 10 | Username: jaytrader75. | 2018-10-30 10:37:57
Intraday data recording state for symbol SNAP is set to download 'Pending'. | 2018-10-30 10:37:57
HD Request # 20 | Downloading Intraday chart data for SNAP to the file SNAP.scid. Service: equities.us | 2018-10-30 10:37:57
HD Request # 20 | Download start date-time: 2018-10-30 10:37:44.000 | 2018-10-30 10:37:57
HD Request # 20 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 10:37:57
Socket (7) | Creating socket. | 2018-10-30 10:37:57
Socket (7) | Connecting to IP: 8.18.161.135. | 2018-10-30 10:37:57
HD Request # 20 | Setting DTC encoding to Binary VLS | 2018-10-30 10:37:57
HD Request # 20 | Sending historical data logon request message. | 2018-10-30 10:37:57
HD Request # 20 | Requesting Intraday data. Start date-time: 2018-10-30 10:37:44. Record interval: 0. Symbol: SNAP | 2018-10-30 10:37:57
HD Request # 20 | Decompressing data. | 2018-10-30 10:37:57
HD Request # 20 | Receiving Intraday data for SNAP starting at 2018-10-30 10:37:44 | 2018-10-30 10:37:57
HD Request # 20 | Timestamp of first Intraday data file record written: 2018-10-30 10:37:49 | 2018-10-30 10:37:57
Socket (7) | Signaling to core to close socket | 2018-10-30 10:37:57
Socket (7) | Shutdown started. Waiting for graceful close. | 2018-10-30 10:37:57
Historical data download thread signaled to stop. | 2018-10-30 10:37:57
HD Request # 20 | Received 2 records from 2018-10-30 10:37:44 to 2018-10-30 10:37:49 (5.0 seconds) and wrote 1 record for SNAP | 2018-10-30 10:37:57
Added 1 Time and Sales records to Intraday data file for SNAP after download. | 2018-10-30 10:37:57
HD Request # 20 | Completion time: 1s | 2018-10-30 10:37:57
HD Request # 20 | Intraday data download complete for SNAP. Unique request ID: 21 | 2018-10-30 10:37:57
Removed historical data download ID 21 | 2018-10-30 10:37:57
Real-time Intraday chart data file updates started for SNAP | 2018-10-30 10:37:57
Intraday chart data file opened for SNAP | 2018-10-30 10:37:57
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 10:37:57
Socket (7) | Closed. | 2018-10-30 10:37:57
HD Server | HD Request #10 | Socket: 6 | Symbol: SNAP | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 3 | ClientRequestID: 10 | Username: jaytrader75. | 2018-10-30 10:37:58
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 10:37:58
Socket (6) | Received socket Close event. | 2018-10-30 10:37:58
Socket (6) | Signaling to core to close socket | 2018-10-30 10:37:58
Socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 10:37:58
Socket (6) | Closed. | 2018-10-30 10:37:58
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 10:37:58
Opened cached Intraday file: C:\SierraChart\Data\ESz18.scid | 2018-10-30 10:37:59
Opened cached Intraday file: C:\SierraChart\Data\HSx18.scid | 2018-10-30 10:37:59
Opened cached Intraday file: C:\SierraChart\Data\SNAP.scid | 2018-10-30 10:37:59
NQZ18 [M] 1 Min #1 | Reloading chart. | 2018-10-30 11:10:36
NQZ18 [M] 2 Min #1 | Reloading chart. | 2018-10-30 11:10:55
NQz18 [M] 3 Min #4 | Reloading chart. | 2018-10-30 12:01:11
NQZ18 [M] 2 Sec #3 | Error writing trade window configuration file. File: C:\SierraChart\Data\Jay first*.twconfig Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2018-10-30 12:09:57 *
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 12:43:13
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 12:46:46
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 12:47:10
NQZ18 [M] 10 Min #1 | Reloading chart. | 2018-10-30 13:00:27
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 13:38:58
Socket (6) | Creating socket. | 2018-10-30 13:38:58
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 13:38:58
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 13:38:58
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 13:38:58
HD Server | HD Request #11 | Socket: 6 | Symbol: RTYZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 00:05:30 | ClientRequestID: 11 | Username: jaytrader75. | 2018-10-30 13:38:58
HD Server | HD Request #11 | Socket: 6 | Symbol: RTYZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 110367 | ClientRequestID: 11 | Username: jaytrader75. | 2018-10-30 13:38:59
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 13:38:59
Socket (6) | Received socket Close event. | 2018-10-30 13:38:59
Socket (6) | Signaling to core to close socket | 2018-10-30 13:38:59
Socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 13:38:59
Socket (6) | Closed. | 2018-10-30 13:38:59
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 13:38:59
NQZ18 [M] 6 Trades #16 | Reloading chart. | 2018-10-30 13:50:28
NQZ18 [M] 6 Trades #16 | Reloading chart. | 2018-10-30 13:50:41
NQZ18 [M] 6 Trades #16 | Reloading chart. | 2018-10-30 13:50:48
NQZ18 [M] 6 Trades #16 | Reloading chart. | 2018-10-30 13:50:58
NQZ18 [M] 6 Trades #16 | Reloading chart. | 2018-10-30 13:51:15
NQZ18 [M] 6 Trades #16 | Reloading chart. | 2018-10-30 13:51:20
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 13:58:54
Requesting market depth updates for: RTYz18 if supported. | 2018-10-30 14:33:35
SC Data - All Services | Clearing market depth for RTYz18. | 2018-10-30 14:33:35
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 14:37:48
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-10-30 14:38:04
NQz18 [M] 2 Min #4 | Reloading chart. | 2018-10-30 14:46:01
NQz18 [M] 3 Min #4 | Reloading chart. | 2018-10-30 15:01:18
NQZ18 [M] 2 Sec #16 | Reloading chart. | 2018-10-30 15:28:56
NQz18 [M] 2 Min #4 | Reloading chart. | 2018-10-30 15:31:38
RTYz18 [M] 3 Sec #3 | Reloading chart. | 2018-10-30 15:42:03
RTYz18 [M] 4 Sec #3 | Reloading chart. | 2018-10-30 15:42:10
RTYz18 [M] 2 Sec #3 | Reloading chart. | 2018-10-30 15:42:41
RTYz18 [M] 3 Min #4 | Reloading chart. | 2018-10-30 15:51:45
NQZ18 [M] 10 Sec #16 | Reloading chart. | 2018-10-30 16:00:50
DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-10-30 16:06:54 *
DTC Client socket (5) | Socket gracefully closed by remote side. | 2018-10-30 16:06:54
DTC Client socket (5) | Received socket Close event. | 2018-10-30 16:06:54
DTC Client socket (5) | Signaling to core to close socket | 2018-10-30 16:06:54
DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 16:06:54
DTC Client socket (5) | Closed. | 2018-10-30 16:06:54
SC Data - All Services | Disconnected from the server. | 2018-10-30 16:06:54
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-10-30 16:06:54
SC Data - All Services | Using username 0 | 2018-10-30 16:06:56
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-10-30 16:06:56
DTC Client socket (5) | Creating socket. | 2018-10-30 16:06:56
DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2018-10-30 16:06:56
SC Data - All Services | Connected to server. | 2018-10-30 16:06:56
SC Data - All Services | Starting socket receive thread. | 2018-10-30 16:06:56
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-10-30 16:06:56
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:56
SC Data - All Services | Sending logon request message. | 2018-10-30 16:06:56
SC Data - All Services | Received logon response. | 2018-10-30 16:06:56
SC Data - All Services | Server Name: SC Realtime Server. | 2018-10-30 16:06:56
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-10-30 16:06:56
SC Data - All Services | Successfully connected. | 2018-10-30 16:06:56
SC Data - All Services | Trading is not supported. | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: 6EZ18 -> 6EZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: 6JZ18 -> 6JZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: 6SZ18 -> 6SZ18 | 2018-10-30 16:06:56
Intraday data recording state for symbol ESz18 is set to download 'Pending'. | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: ESz18 -> ESZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: GCLZ18 -> CLZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: GEZ18 -> GEZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: GGCZ18 -> GCZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: GHGZ18 -> HGZ18 | 2018-10-30 16:06:56
Intraday data recording state for symbol HSx18 is set to download 'Pending'. | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: HSx18 -> HSX18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: LBSF19 -> LBSF19 | 2018-10-30 16:06:56
Intraday data recording state for symbol NQz18 is set to download 'Pending'. | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: NQz18 -> NQZ18 | 2018-10-30 16:06:56
Intraday data recording state for symbol RTYz18 is set to download 'Pending'. | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: RTYz18 -> RTYZ18 | 2018-10-30 16:06:56
Intraday data recording state for symbol YMz18 is set to download 'Pending'. | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: YMz18 -> YMZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: ZCZ18 -> ZCZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: ZNZ18 -> ZNZ18 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: ZSF19 -> ZSF19 | 2018-10-30 16:06:56
SC Data - All Services | Restarting real-time data updates for symbol: ZTZ18 -> ZTZ18 | 2018-10-30 16:06:56
HD Request # 21 | Downloading Intraday chart data for ESz18 to the file ESz18.scid. Service: cme | 2018-10-30 16:06:56
HD Request # 21 | Download start date-time: 2018-10-30 16:06:29.000 | 2018-10-30 16:06:56
HD Request # 21 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 16:06:56
Socket (6) | Creating socket. | 2018-10-30 16:06:56
Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-30 16:06:56
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 16:06:56
Socket (7) | Creating socket. | 2018-10-30 16:06:56
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:56
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 16:06:56
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 16:06:56
HD Server | HD Request #12 | Socket: 7 | Symbol: HSx18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 16:59:56 | ClientRequestID: 12 | Username: jaytrader75. | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol 6EZ18 | 2018-10-30 16:06:56
SC Data - All Services | Clearing market depth for ESz18. | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol 6JZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol 6SZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol ESz18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol GCLZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol GEZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol GGCZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol GHGZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol HSx18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol LBSF19 | 2018-10-30 16:06:56
HD Request # 21 | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:56
HD Request # 21 | Sending historical data logon request message. | 2018-10-30 16:06:56
SC Data - All Services | Clearing market depth for NQz18. | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol NQz18 | 2018-10-30 16:06:56
SC Data - All Services | Clearing market depth for RTYz18. | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol RTYz18 | 2018-10-30 16:06:56
SC Data - All Services | Clearing market depth for YMz18. | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol YMz18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol ZCZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol ZNZ18 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol ZSF19 | 2018-10-30 16:06:56
SC Data - All Services | Received security definition for symbol ZTZ18 | 2018-10-30 16:06:56
HD Request # 21 | Requesting Intraday data. Start date-time: 2018-10-30 16:06:29. Record interval: 0. Symbol: ESZ18 | 2018-10-30 16:06:56
HD Request # 21 | Decompressing data. | 2018-10-30 16:06:56
HD Request # 21 | Receiving Intraday data for ESz18 starting at 2018-10-30 16:06:29 | 2018-10-30 16:06:56
HD Request # 21 | Timestamp of first Intraday data file record written: 2018-10-30 16:06:29 | 2018-10-30 16:06:56
Socket (6) | Signaling to core to close socket | 2018-10-30 16:06:56
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 16:06:56
Historical data download thread signaled to stop. | 2018-10-30 16:06:56
HD Request # 21 | Received 807 records from 2018-10-30 16:06:29 to 2018-10-30 16:06:53 (24.0 seconds) and wrote 794 records for ESz18 | 2018-10-30 16:06:56
Added 1 Time and Sales records to Intraday data file for ESz18 after download. | 2018-10-30 16:06:56
HD Request # 21 | Completion time: 0s | 2018-10-30 16:06:56
HD Request # 21 | Intraday data download complete for ESz18. Unique request ID: 22 | 2018-10-30 16:06:56
Removed historical data download ID 22 | 2018-10-30 16:06:56
Real-time Intraday chart data file updates started for ESz18 | 2018-10-30 16:06:56
Intraday chart data file opened for ESz18 | 2018-10-30 16:06:56
HD Request # 22 | Downloading Intraday chart data for HSx18 to the file HSx18.scid. Service: HongKongFutures.Exchange | 2018-10-30 16:06:56
HD Request # 22 | Download start date-time: 2018-10-30 12:59:56.000 | 2018-10-30 16:06:56
HD Request # 22 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 16:06:57
Socket (6) | Socket gracefully closed by remote side. | 2018-10-30 16:06:57
Socket (6) | Closed. | 2018-10-30 16:06:57
Chart #11 has tagged chart #3 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 16:06:57
Chart #11 has tagged chart #4 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 16:06:57
Chart #11 has tagged chart #5 for full recalculation. Chartbook: Eminisp500 .Cht | 2018-10-30 16:06:57
Socket (8) | Creating socket. | 2018-10-30 16:06:57
Socket (8) | Connecting to IP: 8.18.161.135. | 2018-10-30 16:06:57
ESZ18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 16:06:57
ESz18 [M] 10 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 16:06:57
ESz18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: Eminisp500 .Cht | 2018-10-30 16:06:57
HD Request # 22 | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:57
HD Request # 22 | Sending historical data logon request message. | 2018-10-30 16:06:57
HD Request # 22 | Requesting Intraday data. Start date-time: 2018-10-30 12:59:56. Record interval: 0. Symbol: HSX18 | 2018-10-30 16:06:57
HD Request # 22 | Decompressing data. | 2018-10-30 16:06:57
HD Request # 22 | Receiving Intraday data for HSx18 starting at 2018-10-30 12:59:56 | 2018-10-30 16:06:57
Socket (8) | Signaling to core to close socket | 2018-10-30 16:06:57
Socket (8) | Shutdown started. Waiting for graceful close. | 2018-10-30 16:06:57
Historical data download thread signaled to stop. | 2018-10-30 16:06:57
HD Request # 22 | Received 2 records from 2018-10-30 12:59:56 to 2018-10-30 12:59:56 (0.0 seconds) and wrote 0 records for HSx18 | 2018-10-30 16:06:57
HD Request # 22 | Completion time: 0s | 2018-10-30 16:06:57
HD Request # 22 | Intraday data download complete for HSx18. Unique request ID: 23 | 2018-10-30 16:06:57
Removed historical data download ID 23 | 2018-10-30 16:06:57
Real-time Intraday chart data file updates started for HSx18 | 2018-10-30 16:06:57
Intraday chart data file opened for HSx18 | 2018-10-30 16:06:57
HD Request # 23 | Downloading Intraday chart data for NQz18 to the file NQz18.scid. Service: cme | 2018-10-30 16:06:57
HD Request # 23 | Download start date-time: 2018-10-30 16:06:29.000 | 2018-10-30 16:06:57
HD Request # 23 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 16:06:57
Socket (6) | Creating socket. | 2018-10-30 16:06:57
Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-30 16:06:57
Socket (8) | Socket gracefully closed by remote side. | 2018-10-30 16:06:57
Socket (8) | Closed. | 2018-10-30 16:06:57
HD Request # 23 | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:57
HD Request # 23 | Sending historical data logon request message. | 2018-10-30 16:06:57
HD Request # 23 | Requesting Intraday data. Start date-time: 2018-10-30 16:06:29. Record interval: 0. Symbol: NQZ18 | 2018-10-30 16:06:57
HD Request # 23 | Decompressing data. | 2018-10-30 16:06:57
HD Request # 23 | Receiving Intraday data for NQz18 starting at 2018-10-30 16:06:29 | 2018-10-30 16:06:57
HD Request # 23 | Timestamp of first Intraday data file record written: 2018-10-30 16:06:29 | 2018-10-30 16:06:57
Socket (6) | Signaling to core to close socket | 2018-10-30 16:06:57
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-30 16:06:57
HD Request # 23 | Received 271 records from 2018-10-30 16:06:29 to 2018-10-30 16:06:53 (24.0 seconds) and wrote 268 records for NQz18 | 2018-10-30 16:06:57
Added 6 Time and Sales records to Intraday data file for NQz18 after download. | 2018-10-30 16:06:57
HD Request # 23 | Completion time: 0s | 2018-10-30 16:06:57
HD Request # 23 | Intraday data download complete for NQz18. Unique request ID: 24 | 2018-10-30 16:06:57
Removed historical data download ID 24 | 2018-10-30 16:06:57
Real-time Intraday chart data file updates started for NQz18 | 2018-10-30 16:06:57
Intraday chart data file opened for NQz18 | 2018-10-30 16:06:57
HD Request # 24 | Downloading Intraday chart data for RTYz18 to the file RTYz18.scid. Service: cme | 2018-10-30 16:06:57
HD Request # 24 | Download start date-time: 2018-10-30 16:06:28.000 | 2018-10-30 16:06:57
HD Request # 24 | Using server: ds1.sierracharts.com port 10150 | 2018-10-30 16:06:57
Chart #3 has tagged chart #1 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
Chart #3 has tagged chart #4 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
Chart #3 has tagged chart #6 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
Chart #3 has tagged chart #7 for full recalculation. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
NQz18 [M] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
HD Request # 24 | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:57
HD Request # 24 | Sending historical data logon request message. | 2018-10-30 16:06:57
NQz18 [M] 2 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
HD Request # 24 | Requesting Intraday data. Start date-time: 2018-10-30 16:06:28. Record interval: 0. Symbol: RTYZ18 | 2018-10-30 16:06:57
NQZ18 [M] 10 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
NQz18 [CV] [M] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: nasdaqoriginal1 102918 .Cht | 2018-10-30 16:06:57
HD Request # 24 | Decompressing data. | 2018-10-30 16:06:57
HD Request # 24 | Receiving Intraday data for RTYz18 starting at 2018-10-30 16:06:28 | 2018-10-30 16:06:57
HD Request # 24 | Timestamp of first Intraday data file record written: 2018-10-30 16:06:29 | 2018-10-30 16:06:57
HD Request # 24 | Received 127 records from 2018-10-30 16:06:28 to 2018-10-30 16:06:53 (25.0 seconds) and wrote 103 records for RTYz18 | 2018-10-30 16:06:57
Added 5 Time and Sales records to Intraday data file for RTYz18 after download. | 2018-10-30 16:06:57
HD Request # 24 | Completion time: 0s | 2018-10-30 16:06:57
HD Request # 24 | Intraday data download complete for RTYz18. Unique request ID: 25 | 2018-10-30 16:06:57
Removed historical data download ID 25 | 2018-10-30 16:06:57
Real-time Intraday chart data file updates started for RTYz18 | 2018-10-30 16:06:57
Intraday chart data file opened for RTYz18 | 2018-10-30 16:06:57
HD Request # 25 | Downloading Intraday chart data for YMz18 to the file YMz18.scid. Service: cbot | 2018-10-30 16:06:57
HD Request # 25 | Download start date-time: 2018-10-30 16:06:28.000 | 2018-10-30 16:06:57
HD Request # 25 | Using server: ds7.sierracharts.com port 10149 | 2018-10-30 16:06:57
Chart #11 has tagged chart #3 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 16:06:57
Chart #11 has tagged chart #4 for full recalculation. Chartbook: r2k main .Cht | 2018-10-30 16:06:57
RTYz18 [M] 2 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 16:06:57
Socket (7) | Socket gracefully closed by remote side. | 2018-10-30 16:06:57
Socket (7) | Received socket Close event. | 2018-10-30 16:06:57
HD Server | HD Request #12 | Socket: 7 | Symbol: HSx18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 2 | ClientRequestID: 12 | Username: jaytrader75. | 2018-10-30 16:06:57
Socket (7) | Signaling to core to close socket | 2018-10-30 16:06:57
Socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 16:06:57
Socket (7) | Closed. | 2018-10-30 16:06:57
HD Server | Server thread ending. Socket closed. | Username: jaytrader75. | 2018-10-30 16:06:57
HD Request # 25 | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:57
HD Request # 25 | Sending historical data logon request message. | 2018-10-30 16:06:57
HD Server | New server thread for client has been created for incoming connection. | 2018-10-30 16:06:57
Socket (7) | Creating socket. | 2018-10-30 16:06:57
HD Server | Setting DTC encoding to Binary VLS | 2018-10-30 16:06:57
HD Server | Received login. Requesting authorization. | Username: jaytrader75. | 2018-10-30 16:06:57
HD Server | Login has been authorized. | Username: jaytrader75. | 2018-10-30 16:06:57
HD Request # 25 | Requesting Intraday data. Start date-time: 2018-10-30 16:06:28. Record interval: 0. Symbol: YMZ18 | 2018-10-30 16:06:57
HD Server | HD Request #13 | Socket: 7 | Symbol: RTYZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 20:06:28 | ClientRequestID: 13 | Username: jaytrader75. | 2018-10-30 16:06:57
HD Server | HD Request #13 | Socket: 7 | Symbol: RTYZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 132 | ClientRequestID: 13 | Username: jaytrader75. | 2018-10-30 16:06:57
HD Server | HD Request #14 | Socket: 7 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2018-10-30 20:06:28 | ClientRequestID: 14 | Username: jaytrader75. | 2018-10-30 16:06:57
HD Server | HD Request #14 | Socket: 7 | Symbol: YMZ18 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 7 | ClientRequestID: 14 | Username: jaytrader75. | 2018-10-30 16:06:57
HD Request # 25 | Decompressing data. | 2018-10-30 16:06:57
HD Request # 25 | Receiving Intraday data for YMz18 starting at 2018-10-30 16:06:28 | 2018-10-30 16:06:57
HD Request # 25 | Timestamp of first Intraday data file record written: 2018-10-30 16:06:29 | 2018-10-30 16:06:57
HD Request # 25 | Received 75 records from 2018-10-30 16:06:28 to 2018-10-30 16:06:53 (25.0 seconds) and wrote 68 records for YMz18 | 2018-10-30 16:06:57
HD Request # 25 | Completion time: 0s | 2018-10-30 16:06:57
HD Request # 25 | Intraday data download complete for YMz18. Unique request ID: 26 | 2018-10-30 16:06:57
Removed historical data download ID 26 | 2018-10-30 16:06:57
Real-time Intraday chart data file updates started for YMz18 | 2018-10-30 16:06:57
Intraday chart data file opened for YMz18 | 2018-10-30 16:06:57
RTYz18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: r2k main .Cht | 2018-10-30 16:06:57
Chart #11 has tagged chart #3 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 16:06:57
Chart #11 has tagged chart #4 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 16:06:57
Chart #11 has tagged chart #5 for full recalculation. Chartbook: DOW futures .Cht | 2018-10-30 16:06:57
YMZ18 [M] 5 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 16:06:57
NQZ18 [M] 0.25 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 16:06:58
YMZ18 [M] 3 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: DOW futures .Cht | 2018-10-30 16:06:58
Opened cached Intraday file: C:\SierraChart\Data\NQz18.scid | 2018-10-30 16:06:58
Opened cached Intraday file: C:\SierraChart\Data\ESz18.scid | 2018-10-30 16:06:58
Opened cached Intraday file: C:\SierraChart\Data\RTYz18.scid | 2018-10-30 16:07:01
Opened cached Intraday file: C:\SierraChart\Data\YMz18.scid | 2018-10-30 16:07:01
NQz18 [M] 1 Min #6 | Reloading chart. | 2018-10-30 16:23:51
NQz18 [M] 30 Sec #6 | Reloading chart. | 2018-10-30 16:24:00
Requested login tokens. | 2018-10-30 16:30:35
HTTPS www.sierrachart.com:443 (6) | Creating socket. Using TLS 1.2. | 2018-10-30 16:30:35
HTTPS www.sierrachart.com:443 (6) | Connecting to IP: 204.15.192.108. | 2018-10-30 16:30:35
Received 8 login tokens. | 2018-10-30 16:30:36
HTTPS www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2018-10-30 16:30:41
HTTPS www.sierrachart.com:443 (6) | Received socket Close event. | 2018-10-30 16:30:41
HTTPS www.sierrachart.com:443 (6) | Signaling to core to close socket | 2018-10-30 16:30:41
HTTPS www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-30 16:30:41
HTTPS www.sierrachart.com:443 (6) | Closed. | 2018-10-30 16:30:41
[2018-10-31 21:30:18]
Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol
When using a sub instance of Sierra Chart through File >> New Instance, all data originates from the main instance of Sierra Chart. So in no case will you see the [M] indicator on the chart after the symbol. This is completely normal. It is just enough that you see it in the main instance of Sierra Chart for the symbol.
We did see one lost connection but did not look for any others and that would be a network connectivity issue. That is all we can say.
Date Time Of Last Edit: 2018-10-31 21:30:35
