Date/Time: Sun, 24 Nov 2024 13:06:21 +0000
Minor Problem-V1040
View Count: 1246
[2013-10-31 17:37:14] |
TI Anon - Posts: 36 |
When using "Trading:Triggered Limit Order Entry" the Chart Shortcut Menu does not reset when Target Price is activated and then cancelled, Set Sell and Buy Price stays on the menu. Same problem might be happening with other studies. V1040 |
[2013-10-31 17:50:37] |
We will resolve this. Not certain why it was done that way previously.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-31 17:50:46
