Date/Time: Wed, 22 Jan 2025 23:08:08 +0000
#ARGS! Error when I try to use this code
View Count: 978
[2018-10-31 00:36:37] |
User739131 - Posts: 27 |
Hi. When I try to use the following code I am receiving an Args error message. Can you tell me what I have done wrong? AND(CROSSFROMBELOW(ID7.SG1[-1],ID2.SG1[-1],ID3.SG1>ID3.SG2)) Thanks, MJ |
[2018-10-31 00:50:37] |
Sawtooth - Posts: 4159 |
Try this: AND(CROSSFROMBELOW(ID7.SG1[-1],ID2.SG1[-1]),ID3.SG1>ID3.SG2) |
[2018-10-31 01:21:08] |
Are you trying to use this directly on a Spreadsheet or in an Alert Formula on a study?
