Date/Time: Wed, 22 Jan 2025 23:12:58 +0000
Workspace Scrolling doesnt work as expected...
View Count: 705
[2018-10-30 17:53:43] |
User138602 - Posts: 169 |
Hello, started using this feature. What i recognized: If i am switching to a chartbook, which doesnt need workspace scrolling the scrollbar extends over the full screen, which is fine. BUT if i switch back to a chartbook, that needs scrolling, then the scrollbar remains extended and i cant scroll at all. Right now i help me with going into the options and disable then enable scrolling again. But this cant be intented. Did i miss something? Best Regards |
[2018-10-30 19:01:14] |
That functionality is provided by the Windows operating system and we cannot change its behavior.
