Date/Time: Mon, 20 May 2024 17:01:25 +0000
scale in
View Count: 2420
[2018-10-30 09:55:59] |
User884550 - Posts: 149 |
when scaling in, it often combines my new scale out orders with earlier orders, but I want every scale in to be under 1 combined stop loss, and under separate scale out orders, not combined
[2018-10-30 16:15:22] |
Here is the documentation for using Scaling In: Attached Orders: Scaling In Make sure you understand it, and it is enabled and configured properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-30 16:16:04
[2020-02-16 06:50:15] |
User353062 - Posts: 26 |
For example, 1 contract to start with then scale another contract after 4 ticks or 1 point move up/down. Let me know. |
[2020-02-18 09:13:08] |
With regards to post #3: What is the exact question you have. We do not know what you are asking about here.
[2020-02-18 15:11:41] |
It does not support pending open order in attached order. That is what I'm looking for.
