Date/Time: Wed, 22 Jan 2025 23:02:45 +0000
Wanted - ACSIL Example of interactive menu in chart region
View Count: 1040
[2018-10-30 00:30:02] |
User316362 - Posts: 210 |
Can anyone point me toward an example of a study that supports an "interactive" menu in the chart region? Like a simple on off switch, etc. Date Time Of Last Edit: 2018-10-30 02:34:51
[2018-10-30 15:50:43] |
This is documented on this page: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events The documentation makes reference to specific code examples. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-30 15:51:48
[2018-10-30 23:10:26] |
Excellent, the shortcut menu items will work fine. Thanks for the pointer to the documentation
