Date/Time: Wed, 22 Jan 2025 23:24:56 +0000
Cannot undo line move
View Count: 909
[2018-10-29 20:28:29] |
User654912 - Posts: 26 |
Often when I am panning the chart I accidentally click and move a line and then cannot undo this move. When I click Edit the option to undo is grayed out. Is there a way I can debug this? It would be nice if I could require a Ctrl+click to select a chart drawing so that I can avoid this issue. |
[2018-10-30 05:06:09] |
Edit >> Undo Chart Drawing does support undoing a move. May be that drawing was copied from another chart? There are two possibilities. Disable the option to support the left click selection of chart drawings in Global settings >> Tool Settings. Or disable this option: Chart Settings: Allow Modification of Chart Drawings from Other Charts (Chart >> Chart Settings >> Chart Drawing menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-30 05:06:31
[2018-10-30 12:33:14] |
Yes a lot of my drawings are shared with other charts. Maybe that's what causes this issue. I will try disabling the left click.
