Date/Time: Sun, 24 Nov 2024 12:55:53 +0000
Not getting volume related data
View Count: 1191
[2013-10-31 16:00:54] |
Daniel1957 - Posts: 3 |
I don't get any data for Cumulative Delta Bars-Volume and Bid Ask Volume Ratio before the time I open Sierra. Price updates fine for the previous 90 days that is set in the chart settings, just not these studies. I have the charts set to ticks(1500) and my data provider is IQ Feed. Any ideas?
[2013-10-31 16:24:27] |
Follow the instructions here for tick by tick data storage/configuration: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
