Date/Time: Thu, 23 Jan 2025 00:03:26 +0000
countdown timer
View Count: 722
[2018-10-29 18:09:40] |
stephane1 - Posts: 112 |
hello I can't move and fix a timer . I don't have IN3 in study countdown timer. sierra chart version: 1820 32 bits regards |
[2018-10-29 18:30:19] |
Update to the current version of Sierra Chart: Software Download: Fast Update Refer to the Input descriptions here: Countdown Timer: Inputs And here is the documentation to move the Countdown Timer: Countdown Timer: Moving Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 18:32:00
