Date/Time: Fri, 03 May 2024 08:22:01 +0000
Horizontal line
View Count: 757
[2018-10-29 15:36:29] |
User844839 - Posts: 2 |
How to configure the snap to open or close for the horizontal line on the charts? It only works on the CLZ8 chart! but none of the rest.
Date Time Of Last Edit: 2018-10-29 17:52:07
[2018-10-29 21:47:57] |
John - SC Support - Posts: 31334 |
Are you referring to the Right-Click options for Snap to Open and Snap to Close? If so, then those options are not available for the Horizontal Line. They should not be showing up on any chart.
[2019-10-27 01:52:26] |
j4ytr4der_ - Posts: 918 |
I just came here to figure out this exact issue. Any particular reason horizontal lines can't be snapped to open/close? I would really love to be able to do that quickly & easily, especially on Renko charts.
[2019-10-28 09:48:24] |
We will see if we can add support for this.
