Date/Time: Mon, 05 Oct 2026 06:09:27 +0000
ACSIL: Reward/Risk Tool
View Count: 2843
| [2018-10-29 15:25:51] |
| User185376 - Posts: 1 |
Dear SC-SupportTeam, I use the Reward/Risk Tool with my own ACSIL study. Therefore I use almost the same code you provided in the Studies.cpp. The tool is added just fine, but the option "ShowTickDifference = 1" will not be evaluated by SC. When I configurate the ACSIL drawn tool and add the ShowTickDifference option by myself via Chart Drawing Properties, it works. How can I add the ShowTickDifference flag automatically by ACSIL? Best regards, Matthias s_UseTool Tool; Tool.Clear(); //Tool.ChartNumber = sc.ChartNumber; Tool.AddAsUserDrawnDrawing = 1; Tool.DrawingType = DRAWING_REWARD_RISK; Tool.BeginIndex = sc.Index; // Stop Tool.BeginValue = sc.GetLowest(sc.BaseDataIn[SC_LOW], 2)-1*sc.TickSize; Tool.EndIndex = sc.Index+1; // Entry Tool.EndValue = sc.Close[sc.Index]; Tool.ThirdIndex = sc.Index+5; // Target Tool.ThirdValue = sc.Close[sc.Index]+5*sc.TickSize; Tool.Color = COLOR_WHITE; // text color Tool.TransparentLabelBackground = 0; // opaque labels Tool.TextAlignment = DT_RIGHT; // text alignment (target marker is left/right of text) Tool.ShowTickDifference = 1; // text options Tool.ShowPriceDifference = 0; Tool.ShowCurrencyValue = 0; Tool.FontFace = sc.GetChartTextFontFaceName(); // override chart drawing text font Tool.FontSize = 14; Tool.FontBold = 1; Tool.LevelColor[0] = RGB(192,192,192); // stop to entry line Tool.LevelStyle[0] = LINESTYLE_DASH; Tool.LevelWidth[0] = 2; Tool.LevelColor[1] = RGB(192,192,192); // entry to target line Tool.LevelStyle[1] = LINESTYLE_DASH; Tool.LevelWidth[1] = 2; Tool.LevelColor[2] = COLOR_WHITE; // entry marker Tool.LevelStyle[2] = MARKER_DASH; // marker type Tool.RetracementLevels[2] = 5; // marker size Tool.LevelWidth[2] = 2; // marker width Tool.LevelColor[3] = COLOR_RED; // stop marker Tool.LevelStyle[3] = MARKER_DASH; // marker type Tool.RetracementLevels[3] = 10; // marker size Tool.LevelWidth[3] = 2; // marker width Tool.LevelColor[4] = COLOR_GREEN; // target marker Tool.LevelStyle[4] = MARKER_POINT; // marker type Tool.RetracementLevels[4] = 5; // marker size Tool.LevelWidth[4] = 2; // marker width Tool.Region = 0; Tool.AddMethod = UTAM_ADD_OR_ADJUST; sc.UseTool(Tool); |
| [2018-10-29 19:37:40] |
We will make sure these all of these apply to that particular drawing tool type: Tool.ShowTickDifference = 1; // text options Tool.ShowPriceDifference = 0; Tool.ShowCurrencyValue = 0; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
