Date/Time: Thu, 23 Jan 2025 00:05:47 +0000
Shortening Titles on Volume Profile
View Count: 630
[2018-10-29 13:18:42] |
User123891 - Posts: 20 |
Is there a way to eliminate or shoten the volume profile labels. For example Vol Above/Below last is so long I have to allow extra space to see the number. Please see attached. Thanks http://www.sierrachart.com/image.php?Image=1540819027408.png |
[2018-10-29 17:31:46] |
No, those cannot be changed.
[2018-10-30 15:52:23] |
How about shortening the name altogether? Ask volume - bid volume is shortened to AV-BV. This could be shortened to VA/BL. That would solve my issue and should not be hard to accomplish. Anyone who clicks the box and adds it is going to know what it is anyway. You do not have to spell out the entire words.
[2018-11-01 18:35:24] |
The titles have been shortened in the latest release.
