Date/Time: Thu, 23 Jan 2025 00:06:40 +0000
v1831 Trade Activity P&L on Sub Instance
View Count: 1113
[2018-10-29 11:37:43]
Marmany - Posts: 307
Updated to v 1831 and find incorrect P&L values reported in Trade Activity Log on sub instances.
Correct P&L values are reported in Trade Window and on screen displays on sub instances.
Sub instance Trade Activity log was reporting correctly on previous version (1822).
The issue is same for both Sim and Live Trades
For example YM trade on 1st Instance correctly shows 46.20 profit
Symbol  Trade Type  Entry DateTime  Exit DateTime  Entry Price  Exit Price  Trade Quantity  Max Open Quantity  Max Closed Quantity  Profit/Loss (C)  Running Profit/Loss (C)  FlatToFlat Profit/Loss (C)  FlatToFlat Max Open Profit (C)  FlatToFlat Max Open Loss (C)  Max Open Profit (C)  Max Open Loss (C)  Entry Efficiency  Exit Efficiency  Total Efficiency  Commission (C)  High Price While Open  Low Price While Open  Note  Open Position Quantity  Close Position Quantity
YMZ8  Long  2018-10-26 16:24:14.913  2018-10-26 16:24:22.392  24548  24558  1  1  1  46.20  -395.20  46.20  50.00  -5.00  50.00  -5.00  100.0%  100.0%  90.9%  3.80  24558  24547  Parent order. Tag: Steep Channel  1  0
Activity Log on subinstance shows only 10 profit for the same trade (this value remains the same whether Use Commission is ticked or not)
YMZ8  Long  2018-10-26 16:24:14.922 BP  2018-10-26 16:24:22.402 EP  24548.00  24558.00  1  1  1  10.00  -38.00  10.00 F  10.00  -1.00  10.00  -1.00  100.0%  100.0%  90.9%  0.00  24558.00  24547.00  Steep Channel  1  0
Rolling back to v1822 gives correct values in Trade Activity Log on sub instances
Please advise
Date Time Of Last Edit: 2018-10-29 11:52:42
[2018-10-29 18:42:36]
This has to do with the Symbol Settings not properly copying over to the sub instance. This is all. We will solve this.
The calculation you are seeing is just as a point calculation.
Date Time Of Last Edit: 2018-10-29 18:42:45
