Date/Time: Thu, 23 Jan 2025 00:00:54 +0000
Can you display Open,High,Low, Close when scrolling over Candles
View Count: 853
[2018-10-29 10:06:45] |
User772556 - Posts: 21 |
Is it possible to have sierra chart display the open, close, high, low of candles when you scroll over individual candle sticks? Lets say I am looking at a weekly chart and I put the mouse on the candle, I can I have the chart header, or somewhere to show the numbers for the open, high, low, close?
[2018-10-29 17:58:32] |
Refer to the Chart Values tool here: Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
