Date/Time: Thu, 23 Jan 2025 00:01:50 +0000
Attaching Chart for User Discussion
View Count: 567
[2018-10-28 23:22:37] |
Halco - Posts: 92 |
I'd like to attach a chart with studies to a User Discussion. Do I do this via the "Attaching or Posting a Screenshot/Image" instructions or is there another preferred method? Thanks.
Date Time Of Last Edit: 2018-10-28 23:23:23
[2018-10-29 00:20:23] |
Yes that method can be used because that is a universal method to share a chart image with anyone.
