Date/Time: Wed, 22 Jan 2025 23:59:10 +0000
Where Is The General Settings Config File Located?
View Count: 1418
[2018-10-28 23:02:49] |
Alberto Gauer - Posts: 121 |
I am doing a fresh OS and Sierra install on a dedicated SSD, but I do not want to have to configure all the settings again, I have changed so much stuff to my liking I don't even remember. A lot of different colors, parameters and etc.. In which folder is this file located so I can copy to a USB and then paste it in the right location in the new install?? Thanks Date Time Of Last Edit: 2018-10-28 23:03:58
[2018-10-29 04:42:12] |
Refer to this help topic: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 04:42:18
