Date/Time: Fri, 31 Jan 2025 09:02:37 +0000
study to create upper/lower bands around another study line
View Count: 1079
[2018-10-28 21:55:22] |
User525733 - Posts: 126 |
Hi, Say i have a moving average line or any other study that generates a line/curve....I would like to create a band around it (i.e upper and lower lines that follow the same shape but with a user defined offset). The only way i can do this currently is using the "Study Subgraphs Add" study. However, it requires using a "line study" to define the constant offset...which adds clutter to the already cluttered studies window. Is there a better way of doing this? thanks |
[2018-10-29 17:13:54] |
John - SC Support - Posts: 37621 |
Use this study instead: Study Subgraph Add This adds a value just to a single Subgraph. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 17:22:41
[2018-10-29 17:21:28] |
Sawtooth - Posts: 4164 |
You can also use the Bands/Envelope study, with the 'Based On' set to the moving average study.
[2019-04-26 04:52:02] |
whats1thingnow - Posts: 407 |
for anyone else... i tried 1) bands/envelope based on 'current price line' using fixed value however, since the screen fits the new study bands/envelope, the bars become really small or non existent when i scroll back and price is far away from current price (which usually is in the evening when i do the review) 2) study subgraph add/subtract based on last this works like a charm Date Time Of Last Edit: 2019-04-26 15:44:59
