Date/Time: Wed, 22 Jan 2025 23:11:08 +0000
Number of days until next contract roll
View Count: 650
[2018-10-28 15:51:30] |
User977098 - Posts: 28 |
Hello, I am wanting to access the number of days until the next futures contract roll for a particular symbol and then perform a calculation with this number within the spreadsheet study. Is there anyway to do this or is this only possible via ASCIL? Thanks |
[2018-10-30 05:02:31] |
We will need to look into adding this capability to ACSIL.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-30 05:02:38
[2018-10-31 18:13:45] |
In version 1834 this will be added to ACSIL: sc.ContractRolloverDate. This will apply to the symbol of the chart the study is applied to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 18:14:08
