Date/Time: Thu, 23 Jan 2025 00:13:07 +0000
NB Background Types
View Count: 693
[2018-10-28 14:31:02] |
user8888 - Posts: 159 |
Hello Support, Would you please consider adding a new type of backgroung? the splitted version of the 'Ask Bid Difference Profile' Thank you! |
[2018-10-29 21:26:22] |
John - SC Support - Posts: 37420 |
We are not sure of exactly how this would be put together, so we would need more information on what exactly you are looking for. Have you tried the Back Coloring Option of Based on Diagonal Dominant Side AskVol BidVol Percentage, which will color the background depending on which diagonal is dominant, or which percentage is greater if both are dominant. You will find the documentation for this here: Numbers Bars: Background Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
