Date/Time: Thu, 23 Jan 2025 00:06:32 +0000
Crosschair data visible on X and Y-axis
View Count: 610
[2018-10-28 12:22:55] |
manfretto - Posts: 117 |
Hi, Is it possible to make crosschair value for X (date&time) & Y(price) position to be displayed directly on price/date&time axis not only in the compact chart value window? Best Regards, Slawomir |
[2018-10-28 20:55:15] |
Yes this is the case by default unless you disabled this. Refer to these options: Chart Drawing Tools: Chart Values Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
