Date/Time: Thu, 23 Jan 2025 00:12:33 +0000
[User Discussion] - Realtime symbol amounts
View Count: 591
[2018-10-27 18:20:00] |
User226486 - Posts: 27 |
Hi SC, With regards to the amount of real-time-symbols amount. If I only watch a maximum of 10 different stocks on any given day. What would be the preferred amount of real-time symbols to subscribe to? |
[2018-10-27 20:37:51] |
You just need the 20 symbol limit. This will be fine.
