Date/Time: Wed, 22 Jan 2025 23:58:52 +0000
profit loss connection line ?
View Count: 622
[2018-10-26 12:09:58] |
User20450 - Posts: 330 |
SEEMS LIKE there is a issue with this on reverse candles , please advise
Private File |
[2018-10-26 16:52:37] |
Is that chart scrolled to the very end?
[2018-10-27 14:59:10] |
yes of course , i wouldn't waste ur time like that
[2018-10-29 21:03:35] |
Therefore, this would seem to be a time stamping issue for the order fill which is explained here: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts But really we are not sure that explains it. Ultimately we would have to get the Trade Activity Log file from you and that chart and also know the time zone. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 21:04:23
