Date/Time: Wed, 22 Jan 2025 20:47:30 +0000
"Display Attached Order P/L Always" Option not displaying correct values?
View Count: 1131
[2018-10-26 08:22:04] |
samual sprat - Posts: 343 |
Hi, I've got a bracket order set with 2 lots. It's got 2 TP targets (5 ticks and 10 ticks) and a Stop All of 5 ticks. Under Chart Trade Settings, if I set the option to "Display Attached Order P/L Always" then on the order lines on the chart the Stop currency amount is showing -50.00C instead of -100.00C. This is true for Working orders and also Filled orders. Is this an error? Thanks S Date Time Of Last Edit: 2018-10-26 08:25:29
[2018-10-26 18:27:47] |
The calculation looks correct for us: http://www.sierrachart.com/image.php?Image=1540578412967.png Refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
