Date/Time: Wed, 22 Jan 2025 20:37:42 +0000
Number Bars new Background Coloring Method
View Count: 688
[2018-10-26 00:46:33] |
User99934 - Posts: 227 |
Could you please add Color Code Volume Bars Based on Percent of POC to Number Bars please? Reason: 1) When using Volume by Price and various number bar combinations together, there is frequent overlap. 2) This will allow study to be used on pullback column. |
[2018-10-26 17:40:29] |
We will see about this but not likely would get to it until months from now.
