Date/Time: Wed, 22 Jan 2025 23:23:49 +0000
orders not showing in the new instance
View Count: 999
[2018-10-25 16:38:17] |
dominikos - Posts: 106 |
I cannot get orders to show up in new instance. I can see them in the main window, but I cannot see them when I start a new instance. Is it by designed? My environment: IB with SierraChart data feed |
[2018-10-25 19:16:53] |
Are you referring to open orders? The first thing to do is to see if they are listed in Trade >> Trade Orders and Positions >> Orders In the sub instance.
[2018-11-02 16:43:25] |
I can see them in Trade orders and Positions window but they don't show on the chart, even I have "show orders and positions" enabled.
[2018-11-02 17:34:16] |
Okay this would be due to a difference of the Symbol or Trade Account. They both must match. Also refer to: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-02 17:34:28
[2018-11-03 12:04:50] |
Thank you, it was set to a simulation account.
