Date/Time: Wed, 22 Jan 2025 20:47:46 +0000
Sierra Trader P/L Calculation incorrect
View Count: 1142
[2018-10-24 23:25:38] |
User553586 - Posts: 4 |
Have you run into this on Sierra Charts SIM? The p/l is calculating incorrectly. See the attached image. Please advise. |
To Sierra Chart.Incorrect running P.L Calculation.png / V - Attached On 2018-10-24 23:24:57 UTC - Size: 521.28 KB - 335 views |
[2018-10-24 23:27:45] |
I think I may have figured out my own question do those values mean what the worse drawn down was while being in the trade?
[2018-10-25 00:16:33] |
What version are you noticing this with? If it is with the current version, 1828, we think there is a problem with the underlying data itself which you cannot see due to rounding. For the record you are using CQG data but it would seem unlikely there is a problem with that unless you have set the option to record bid and ask average prices in the global symbol settings. We are not able to reproduce any problem like this. The answer to post #2 is no. Here's an example from our testing: Symbol Trade Type Entry DateTime Exit DateTime Entry Price Exit Price Trade Quantity Max Open Quantity Max Closed Quantity Profit/Loss (T) Running Profit/Loss (T) FlatToFlat Profit/Loss (T) FlatToFlat Max Open Profit (T) FlatToFlat Max Open Loss (T) Max Open Profit (T) Max Open Loss (T) Entry Efficiency Exit Efficiency Total Efficiency Commission (T) High Price While Open Low Price While Open Note Open Position Quantity Close Position Quantity
CLZ18 Long 2018-10-21 21:49:12.003 BP 2018-10-21 21:56:55.014 EP 69.39 69.35 1 1 1 -4 -4 -4 F 0 -5 0 -5 100.0% 20.0% -80.0% 0 69.39 69.34 1 0 CLZ18 Short 2018-10-21 22:04:18.003 BP 2018-10-21 22:11:34.003 EP 69.43 69.45 1 1 1 -2 -6 -2 F 2 -2 2 -2 100.0% 0.0% -50.0% 0 69.45 69.41 1 0 this is using the Sierra Chart exchange data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-25 00:17:11
