Date/Time: Wed, 22 Jan 2025 20:56:58 +0000
Proper Symbol for CL RB Crack spread
View Count: 1877
[2018-10-24 17:23:15] |
User832512 - Posts: 22 |
From the CMEGROUP web site, it looks like 1:1 Crack Spread for (CL RB) or (CL HO) are 1:1 in the same month and use a multiplier of (42 x RB) - (CL) for charting the spread. It looks like SC has preconfigured the symbols to use for these 1:1 Crack spreads, but as I look through the documentation I'm still a bit confused if I'm choosing the correct symbol for DEC 2018 (RB CL) 1:1 Crack Spread. Could you help point out the correct symbol to use? Or, should I be synthetically creating this spread with (42 x Dec RB - Dec CL)? Is there an advantage either way?
[2018-10-24 18:30:23] |
From what we can tell this will be the correct symbol: CL:C1 RB-CL Z18.FUT_SPREAD.NYMEX Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-24 18:31:50
