Date/Time: Wed, 22 Jan 2025 20:56:26 +0000
chartbook freeze
View Count: 619
[2018-10-24 15:08:30] |
User587075 - Posts: 10 |
When I open SC, and then try to open my CB it freezes. Tried dozens of time and still the same end result.
[2018-10-24 17:26:06] |
You will need to start a new Chartbook. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
