Date/Time: Thu, 23 Jan 2025 00:12:25 +0000
Trade Activity Log : Commissions issue on short positions
View Count: 745
[2018-10-24 08:05:39] |
User877753 - Posts: 152 |
Hello, SC 1827 There seems to be some issue here with commissions on short positions : see attached image (sim account)- Same issue occurs with real account. Short positions : Commission appears as a negative number, which seems then substracted from PL ==> the net PL is incorrectly greater than the P&L without commission. Long positions : Commission appears as a positive number, which seems then substracted from PL ==> the net PL is correctly smaller than the P&L without commission. Hope this helps, Regards, JM |
commission.png / V - Attached On 2018-10-24 08:02:44 UTC - Size: 93.81 KB - 248 views |
[2018-10-24 09:05:07] |
We are checking on this.
[2018-10-24 09:30:19] |
This will be resolved in the next release coming out later today.
[2018-10-24 16:44:58] |
User924791 - Posts: 12 |
Negative commission values for short trades problem persists in v. 1828
[2018-10-24 17:07:39] |
There has not been a new version released yet.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-24 17:07:47
[2018-10-25 15:58:55] |
V. 1829 has fixed the negative commission problem. Thanks! However, the FlatToFlat Profit/Loss (C) column is incorrect when Use Commission is checked. There are redundant commission subtractions causing the FlatToFlat P/L to be less than it should be. The attached image demonstrates the problem. |
FlatToFlatPL commissions.png / V - Attached On 2018-10-25 15:57:13 UTC - Size: 92.82 KB - 265 views |
[2018-10-25 16:30:44] |
Thank you for letting us know. We will solve this today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-25 16:31:00
[2018-10-27 18:05:05] |
V. 1830 now displays different numbers in the FlatToFlat Profit/Loss column than 1829. Still wrong. |
FlatToFlatPL commissions.png / V - Attached On 2018-10-27 18:03:07 UTC - Size: 143.36 KB - 281 views |
[2018-10-27 23:05:51] |
We are checking on this now.
[2018-10-27 23:26:07] |
This will be resolved in 1831 we are putting out now.
