Date/Time: Wed, 22 Jan 2025 20:55:25 +0000
[Programming Help] - Can't get help with ZigZag
View Count: 627
[2018-10-23 20:19:26] |
User731023 - Posts: 138 |
Originally posted on the 16th. Need to know if functionality that shows available is not working or something I need to do. 10 /16 Hi, I want the values to paint red or green on ZigZag like it does for the Calculated Bars study. (Screenshot enclosed) I have set to do it to no avail. Am I am doing something wrong? Thanks as always. |
[2018-10-23 21:03:23] |
Auto Coloring for the Custom Text Draw Style does not work unless it is specially implemented. This is not implemented with the Zig Zag study. It is not something we would do either. We really should disable that control when Custom Text is selected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
