Date/Time: Wed, 22 Jan 2025 20:58:13 +0000
Numbers bars issue
View Count: 637
[2018-10-23 17:11:53] |
User211459 - Posts: 1 |
When I switch to Numbers bars in Sierra, my charts become blank. Is there a reason for this? Cedric |
[2018-10-23 17:26:47] |
tesseract353 - Posts: 66 |
Have you implemented all the instructions correctly? Numbers Bars: Step-By-Step Instructions |
[2018-10-23 20:06:22] |
You need to be on the Service Package 5 for Numbers Bars functionality. You will need to ask your broker to put you on service package 5 since your Sierra Chart account is provided through them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-23 20:06:29
